Milodon SB HV Water Pump #2275308
03/24/17 11:39 AM
03/24/17 11:39 AM
Sac, CA
mopowers Offline OP
mopowers  Offline OP
Sac, CA
Does anyone know if the Milodon #16250 high volume small block water pump is the same as the GMB HP SB water pump (#1201070P). I noticed my Milodon unit has the same "GMB CR07" cast on the inlet as the GMB unit does.
Milodon:
https://www.summitracing.com/parts/mil-16250/overview/make/dodge
GMB:
http://www.rockauto.com/en/moreinfo.php?pk=3096414&cc=1498099&jsn=433
Re: Milodon SB HV Water Pump [Re: mopowers] #2275670
03/24/17 11:45 PM
03/24/17 11:45 PM
that would convince me that they are the same (same casting for sure with maybe some mods) but w pumps are pretty simple. Just me I think if you got a parts house rebuilt with the most vanes & welded on an anticav plate that your cooling needs would be met (at least as far as the pump goes).
Re: Milodon SB HV Water Pump [Re: mopowers] #2275694
03/25/17 12:18 AM
03/25/17 12:18 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Myself, over the last 40+ or so years have seen ZERO benefit to anything other than a parts store pump on street driven / occasionally race vehicles. Same with water wetter, duralube and other MAGIC fixes. OPPPS, whistling
I just remembered, there was a noticeable difference, My wallet was lighter twocents popcorn
Re: Milodon SB HV Water Pump [Re: mopowers] #2275722
03/25/17 01:07 AM
03/25/17 01:07 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
My Flowkooler #1700 HiFlow pump has the same casting number on the neck (CR07 GMB).
I think the aftermarket companies use the same base casting but they machine it for their own pump assemblies.
Re: Milodon SB HV Water Pump [Re: YO7_A66] #2275752
03/25/17 01:42 AM
03/25/17 01:42 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
The only one that I know of that is made from a unique casting are the Edelbrock versions. They have a large steel disk with long curved blades that have much more surface area compared to the rest of them. They cost a lot more, but they do work great.
Re: Milodon SB HV Water Pump [Re: Neil] #2276047
03/25/17 04:09 PM
03/25/17 04:09 PM
On the water wetter, I've heard that a few drops of liquid dish soap works good.
