67 coronet vert quarter window mechanism interchange #2275542
03/24/17 07:43 PM
03/24/17 07:43 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
67 coronet convert needs a rear quarter window regulator, i am reading 67-70's interchange but its that convert as well? if not what fits?
Re: 67 coronet vert quarter window mechanism interchange [Re: chrisf] #2275605
03/24/17 09:45 PM
03/24/17 09:45 PM
Eugene, Oregon
minivan Offline
Happy Birthday minivan  Offline
Eugene, Oregon
66 - 70 verts all use the same qtr glass so I would assume the regulator is the same.. pretty special hardware in the qtr... Not sure if the gears "only" ( crank mechanism) would work from a hard top or sedan if you have the rest of the qtr hardware...
