69 Dart steering column reassembly question #2274899
03/23/17 05:21 PM
03/23/17 05:21 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
A while back I disassembled the steering column from my 69 Dart to restore it. I am in the process of reassembling it and have a question. I have these two square head bolts/nuts that came out of the upper collar and I don't recall what they are for. I know the bolts go through the two holes that have the slots (that capture the square heads to keep them from turning) from the back side of the collar. But I have all of the column parts accounted for and it doesn't look like these bolts held anything in place. The column is a floor shift column so I'm wondering if they are possibly used on column shift columns. If not, what are they for?
Re: 69 Dart steering column reassembly question [Re: 440mopar] #2274938
03/23/17 06:47 PM
03/23/17 06:47 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
This is a floor shift column out of a '69 RR - probably similar. You can see how one is holding the plate. The other is obviously under the turn signal switch. If I recall they secure the bottom collar.
Re: 69 Dart steering column reassembly question [Re: 440mopar] #2277925
03/28/17 07:36 PM
03/28/17 07:36 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
The square head of the 2 bolts actually slip into slots in the tube below it.
Once tightened down they retain the collar to the tube ( not seen once everything is tightened down )
