leaf spring specs #2274443
03/22/17 08:42 PM
03/22/17 08:42 PM
minnesota
dk426 Offline OP
dk426  Offline OP
minnesota
what is the torque specs for u-bolts and spring eye bolts for a 63 plymouth b-body Thanks
Re: leaf spring specs [Re: dk426] #2274467
03/22/17 09:27 PM
03/22/17 09:27 PM
I think the 1/2" fine thread ubolts/nuts would be the std 45 lbs.
Re: leaf spring specs [Re: RapidRobert] #2274566
03/23/17 12:06 AM
03/23/17 12:06 AM
IN
ahy Offline
ahy  Offline
IN
I too would suggest 45 ft lb. This is factory spec at least for '70 with similar U bolts. Too tight will bind it up and make it "pop" on bumps.
Always a good idea to re-check torque after driving a while.
Re: leaf spring specs [Re: ahy] #2274568
03/23/17 12:12 AM
03/23/17 12:12 AM
On the spring eye bolt I would suggest looking up the spec for the dia/coarse or fine threads/grade 8 bolt.
Re: leaf spring specs [Re: dk426] #2274575
03/23/17 12:22 AM
03/23/17 12:22 AM
None
71rm23 Offline
71rm23  Offline
None
FSM
Re: leaf spring specs [Re: dk426] #2274716
03/23/17 11:52 AM
03/23/17 11:52 AM
moparx Offline
moparx  Offline
from the FSM :
front pivot nut : 125ftlb.
shackle bolt nut : 30ftlb.
u bolt nut : 45ftlb.
front spring hanger to body bolt : 30ftlb.
rear shock mounting nuts : upper-25ftlb. lower-50ftlb.
beer
Re: leaf spring specs [Re: dk426] #2274766
03/23/17 01:18 PM
03/23/17 01:18 PM
minnesota
dk426 Offline OP
dk426  Offline OP
minnesota
Re: leaf spring specs [Re: ahy] #2274871
03/23/17 04:27 PM
03/23/17 04:27 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Where does the pop come from? Do the leaves move relative to each other within the few inch span between the u-bolts?
Re: leaf spring specs [Re: mopowers] #2275593
03/24/17 09:30 PM
03/24/17 09:30 PM
IN
ahy Offline
ahy  Offline
IN
I do believe there is some movement of the leafs relative to each other. If it is too tight, pressure builds up then it moves/pops. I over torqued my U bolts once and had the pop on bumps. Back them off and correct torque fixed it.
