Re: Need engine bay wiring picture of 1991 W250 360
[Re: Adam71Charger]
#2274196
03/22/17 12:48 PM
03/22/17 12:48 PM
Posts: 139 Pennsylvania
polaris400cc
Pennsylvania
Those alternator's have the voltage regulator built into them, and you have some crazy hack job that you inherited.
Edit... I may be incorrect about ALL of them having the internal regulator, but on a side note the external regulator is not going to work without the case being grounded.
[Re: polaris400cc]
#2274232
03/22/17 02:16 PM
03/22/17 02:16 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
IIRC, the PCM handled regulator duties in those years. 2¢
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: jerseybud]
#2274332
03/22/17 04:53 PM
03/22/17 04:53 PM
Posts: 1,521 Tacoma, Washington USA
Adam71Charger
Charging is controlled by the computer from 88-up 5.2 and 89-up 5.9 trucks. Usually throws a code 41. The external regulator is a common fix, but its supposed to be on the firewall and grounded case to the firewall, not just dangling on the valve cover.
What is code 41? What happened that made the previous owner splice in a voltage regulator?
[Re: Adam71Charger]
#2274622
03/23/17 01:39 AM
03/23/17 01:39 AM
Posts: 954 garnett kansas
rhad
garnett kansas
years ago i bought a 90 w150 that had a external regulator wired into it,turns out the regulator part of the ecm was bad
my ladder of success is missing some rungs
[Re: Adam71Charger]
#2275101
03/23/17 11:59 PM
03/23/17 11:59 PM
3hundred
Colleyville
Those rebuilt PCM's are really dicey. I think I'd mount the regulator and rewire it neatly. 2¢
Robert
[Re: 3hundred]
#2275139
03/24/17 01:05 AM
03/24/17 01:05 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Do you have to pass an inspection where your at? Unfortunately not an option for most, but I yank the whole mess and re-do it as if it was a '72. Parts are all available here, over the counter.
I have mechanical Aptitude. I can screw up anything.
