Page 6 of 7 < 1 2 3 4 5 6 7 >
#2267958 - 03/12/17 10:46 AM Re: Comp Hydraulic Roller for Magnum [Re: AAR-B4]
dsd70bee Offline
Loc: oak park, il.
1968 to 1974 V8 oil pressure sending unit for cars with an oil pressure gauge, NOS in the box, never been installed on an engine, part #3488609 $175.00 (708)288-2879 Scott
#2268255 - 03/12/17 06:59 PM Small Block Misc Brackets [Re: moparts]
C_B5 Offline
Loc: Ohio
Brackets for small block engines
Pulley $20
motor mount $20
All other brackets $10.00 each
Big Block Distributor hold down $15
Send PM or email c-b5@zoominternet.net
#2268853 - 03/13/17 06:36 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts]
schmitty Offline
Loc: IN
Greetings - I have a new set of Percy's seal for good header gaskets for LA engines 273,318,340, and 360. Also included is a complete set of good used (clean - exc. cond) ARP hex headed stainless header bolts. Rock solid combination. Cannot use wtih my new set up. $40.00 + actual postage. Best to call 260-223-0868 or schmittyjsathotmaildotcom Thanks Moparts!
[img:center]http://[/img]
Edited by schmitty (03/13/17 07:11 PM)
#2268893 - 03/13/17 07:46 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts]
Moparteacher Offline
Loc: Boise
**SOLD** Thanks Moparts
https://boise.craigslist.org/pts/6042855202.html
New
Billet 4-hole tapered 1-inch carburetor spacer.
1-3/4 (1.750") hole diameter.
CSI now known as CSR.
Sells new for $131.97 from Summit Racing.
https://www.summitracing.com/parts/csi-004110c/overview/
Your cost $50 plus the ride.
Holley, Demon, QFT, Pro-Systems, Braswell, BLP, Carter, Edelbrock
moparteacher@yahoo.com
Edited by Moparteacher (03/16/17 05:27 PM)
#2268908 - 03/13/17 07:56 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts]
Loc: Boise
**SOLD**Thanks Moparts
New Holley Red fuel pump. Carburetor only. Requires regulator.
Originally sold through Quick Fuel. Still in QFT box.
$50 plus the ride
https://boise.craigslist.org/pts/6042867293.html
#2269021 - 03/13/17 09:44 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts]
qwkmopardan Offline
Loc: Affton MO
340 X heads. Rebuilt. hardened exh. seats--guides--stainless valves--surfaced--positive seals--comp cams springs for hyd cam--115lbs. seat--285lbs at .480" lift--Hi-perf. valve job. No porting. $750 + actual shipping.
#2269285 - 03/14/17 10:56 AM 1967-1968 Exhaust manifolds 273-318 [Re: moparts]
Crazy73 Offline
Loc: CT - just outside Hartford
Set of exhaust manifolds, part numbers reflect 1967-1968 Dart - Barracuda 273 & 318. Passenger manifold also correct for 1968 Charger 318. Passenger manifold has bolt through heat riser.
$35 plus shipping for the pair, payment via PayPal
Please send message!
Located in Manchester CT
Pete
-1968 Barracuda 4spd 383-6pk
#2269290 - 03/14/17 10:59 AM 340 Intake manifold 3671918 [Re: moparts]
Crazy73 Offline
Part number is correct for 1972-1973 engine 340 cid.
Date stamp 7-28-72
As shown, a little hay from the barn can be included at no extra charge!
$40 plus shipping, payment via Paypal
Please send a message!
Pete
#2269344 - 03/14/17 12:20 PM Re: MP cast valve covers [Re: Crazy73]
cudadoug Online   content
Loc: Between a rock & a hard place
Small block MP cast valve covers, fresh bead blast excellent shape with oil baffles in place - $75 plus the ride to you.
Feel free to email: dmayle@cheemafreightlines.com
Or call/text: 209-321-1747
Thanks!
Edited by cudadoug (03/14/17 12:23 PM)
#2270183 - 03/15/17 06:52 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts]
blue_stocker Offline
Loc: What's left of GOD's country, ...
Used Edelbrock 'Elite' valve covers for 273-318-340-360 Chrysler, very good condition, $100 plus shipping. PM me here if interested, thanks...
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them.
Thomas Jefferson
#2270372 - 03/16/17 12:08 AM Re: For Sale - 408 stroker motor [Re: blue_stocker]
krw71ragtop Offline
Loc: USA
This motor was installed in my 1977 Power Wagon to break the camshaft in and was driven about 20 miles. I used Brad Penn 20W50 along with zinc additive during break-in. It will run on 92 octane pump gas. Intentions were to build the motor for low end torque to use it for pulling a car hauler and plowing snow. I purchased another truck, so now the motor is on an engine stand for sale.
I port matched the intake manifold to the head intake ports.
The crankshaft (rotating assembly) was balanced and I was told by the Machine shop owner it looked like a Scat cast crank that is chamfered. Crank was turned .010" on the rods and .020" on main bearings. The piston domes were trimmed on the edge for piston to valve clearance.
.036" quench
Rod and main bearing clearance was measured at .002-.003".
Valve lash was set at ¾ turn.
Camshaft was installed straight up with a 3 way timing gear adjustment.
Compression Calculator
Cylinder Head Volume (cc) 62 Cylinder Head Vol (cubic in.) 3.782
Piston Head Volume (cc) 25
Piston Head Vol (cubic in.) 1.525
Gasket Thickness (in.) .030
Swept Volume (cubic in.) 50.769
Gasket Bore (in.) 4.2
T.D.C. Volume (cubic in.) 5.509
Cylinder Bore Diameter (in.) 4.02
Gasket Volume (cubic in.) 0.443
Deck Clearance (in.)
Note; Neg number above deck, pos. number below deck
.019 Deck volume
Deck Volume (cubic inch) -.0241
4” stroke
STATIC COMPRESSION RATIO 10.216
Rod Length (in.) 6.123
Adjusted Stroke (in.) 3.393
Intake Closing Point
(degrees) ABDC @ 0.050 lift
plus 15 degrees -54
DYNAMIC EFFECTIVE
COMPRESSION RATIO 8.817
1978 360/408" Block
Bored .030" /Squared
Notched for rod clearance
Oil Crossover Tube Modification
New Freeze plug set
Rotating Assembly
Chamfered Crank Shaft
Rod rotating-513
Rod rotating-513
Rod bearing 46.5
Rod bearing-46.5
Oil allowance-6
Piston & Pin-591.5
Locks (1 set) X
Rings (1 set) 56.5
Rod reciprocating- 208
Bobweight total- 1981
Note: 50% Reciprocating, 100% Rotating
Keith Black Pistons KB356-030
Stock rods
ARP main bolts
ARP rod nuts and studs
Clevite rod bearings
King main bearings
Reproduction truck oil pan
Modified Dipstick Tube
Melling HV Oil Pump
Wix Oil Filter
Summit SFI harmonic balancer #A640195
587 Iron Heads Nicely Ported
Stainless Steel Valves
2.02 intake/1.66 exhaust
Bronze valve guides
Adjustable roller rocker arms (unknown brand)
Crane Cams rocker arm adjuster screws #crn-99802-16
Custom Made Ball & Cup Pushrods
Cometic Head gaskets #245-C5633-030
Howard's Cam & lifters #CL710581-10
Hydraulic flat tappet 230/236, 277/283, .531"/.537", 110+4 L/C
Double roller timing chain & gear set
Timing chain tensioner DCC-5007709
Stock Mopar Distributor
Standard Dist. Cap & Rotor Plug wires
Champion spark plugs RN12YC
Hardened Dist. Gear Drive DCC-3690715
Hardened fuel pump eccentric
Carter Fuel Pump #M6866
Mickey Thompson Valve covers
Edelbrock Performer 318/360 Intake Manifold
Hollley 670 Street Avenger Carb
Howard's computer dyno on this build with a 750 carb is 400 hp. @5000 rpm's & 475 @ torque 4000 rpm's.
Asking $4250 OBO
Or trade for truck camper
Located in Michigan 48661
Prefer to be picked up
989- seven zero nine zero four eight four
NO TEXT MESSAGES
#2270455 - 03/16/17 09:32 AM Re: W9 Heads [Re: moparts]
TimDavis Offline
Loc: Indiana
W9 heads for sale needs seats and guides already CNC ported
$1500.
Tim Davis
317-437-9513
Can text Pictures
Edited by TimDavis (03/16/17 09:33 AM)
Edit Reason: Spelling
#2270463 - 03/16/17 09:38 AM Re: R4 block [Re: TimDavis]
TimDavis Offline
Loc: Indiana
R4 wedge block new, could be the last new one on earth.
$2000 that is a bargain for the best wedge block Chrysler ever made.
Tim Davis
317-437-0513
Edited by TimDavis (03/16/17 10:45 AM)
#2270465 - 03/16/17 09:41 AM Re: W8 Heads [Re: TimDavis]
TimDavis Offline
Loc: Indiana
W8 drag race castings. New and very rare.
$1500
Tim Davis
317-437-9513
Can text photos
Edited by TimDavis (03/16/17 10:36 AM)
#2270484 - 03/16/17 10:33 AM Re: R3 block [Re: TimDavis]
TimDavis Offline
Loc: Indiana
New R 3 block for Wedge, 2.250 mains,
60 mm cam 9.00 deck.
$1900
317-437-9514
Tim Davis
#2271058 - 03/17/17 09:08 AM Re: 1970 340 stuff [Re: TimDavis]
chrisnben Offline
Loc: Madison, Wisconsin
1970 340 engine components for sale. (lowered prices-firm)
E-body 340 exhaust manifolds, very clean, not pitted, stock without emissions door $350/pair
1970 340 intake manifold #2531915-2. Still wears it's orange paint. good condition $150
1970 Carter AVS carburetor for 340 #K8-4617S. 625 CFM, I believe. Will include correct return bracket and dual springs and carb linkage. Clean, but I would put a kit in it- been idle for 5 years. $300
1970 340/LA Starter $60
340/318 engine mount brackets, hardware & good isolators. $50
PM me here, I have to get pics up. Thanks! All items are plus shipping.
Edited by chrisnben (03/20/17 08:54 AM)
'70 Cuda "Badfish 2"- in the works
Home of MoPar University- We school 'em one at a time!!
#2272516 - 03/19/17 05:35 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts]
JRepucci Offline
Loc: Sacramento,California
1970 340 auto distributor 3438325 $100
Edited by JRepucci (03/20/17 01:27 AM)
#2273476 - 03/21/17 12:14 AM Re: For Sale - 408 stroker motor [Re: krw71ragtop]
Highwaystar94 Offline
Loc: Colorado, Way up high
This is not a discussion forum.
Edited by tboomer (03/21/17 07:09 AM)
Edit Reason: not a discussion board
'94 Dodge Ram 1500
#2273909 - 03/21/17 06:58 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts]
Loc: Boise
16 New Chrysler 3004647 Flat Hydraulic Lifters (Tappets) - $100
https://boise.craigslist.org/pts/6054322755.html
New (old stock) OEM Chrysler flat tappet hydraulic lifters for big block and small block.
In original packaging, still covered in Cosmoline, or some other factory rust inhibitor.
These will fit Chrysler, Dodge, Plymouth, small block and big block engine from the early sixties till the Magnum motors in 1992 with hydraulic flat tappet valve train.
No oiling hole so probably no suitable for AMC.
These measure .904 diameter, 1.850 in overall height, and 1.450 from center of oil groove to bottom.
NO RUST, but hardened rust inhibitor. These will need to be soaked in cleaner or disassembled and cleaned. Easy-peasy-lemon squeezy.
273, 318, 340, 350, 360, 361, 383, 400, 413, 426 wedge and Hemi, 440.
$100 plus shipping from 83706
Payable through Paypal, cash, cashier's check please.
Thanks for looking
702-349-3789
#2274870 - 03/23/17 02:27 PM Re: For Sale - Small Block Engine - 1st Quarter [Re: moparts]
JRepucci Offline
Vintage 340 TM5 Edelbrock Aluminum single plane intake, NOS $200
24,484 Registered Members
178,561 Topics
Anyone here near Colville, Washington?
by 300by500
22 minutes 6 seconds ago
Spark plug for 511 break in
by mopar dave
28 minutes 59 seconds ago
What's missing, charcoal canister?
by cnxt
Yesterday at 11:26 PM
Anyone into 1972 Olympic stuff ? (Germany)
by OzHemi
Yesterday at 11:20 PM
