#2272678 - 03/19/17 10:13 PM 5.7 hemi misfire help
keith airgrabber Offline
Right in the Nutz!!!
Loc: wisconsin united states
Hi guys I have a 2005 300C. I noticed a misfire going down the highway at about 55 MPH. Stopped to get gas took off and car studdered alot. Made it home fine. Next day made a 30 mile drive no issues. No check engine light yet. Went back home and car misfired down the highway very badly pulled over took off again barely got going so many misfires happening. check engine light came on along with ESP BAS. What the heck is that. Made it home in a limp mode I guess. Check engine codes are
P0300-Random misfire detected
P0016-Crankshaft Position-Camshaft PositionCorrelation-Bank 1 sensor A
P0339-Crankshaft Position SensorA circuit Intermittent
I changed out all spark plugs today and disconnected battery to get engine light off. . Took car for a ride and misfire happened again. No engine light yet but am sure it will pop back on. I was thinking on looking into changing both crank and cam sensors next . Car has 140,000 miles. I hate to take it in and get raped. I like doing things myself when ever I can to save cash. Any opinions would be appreciated. Thanks
#2272680 - 03/19/17 10:15 PM Re: 5.7 hemi misfire help [Re: keith airgrabber]
also wanted to add that it seems like it only misfires when car warms up all the way.
#2272864 - 03/20/17 09:17 AM Re: 5.7 hemi misfire help [Re: keith airgrabber]
sycboi Offline
Loc: Norwalk, Ohio
Most likely it's the crankshaft position sensor. I've heard it can be several different things, but the Crank sensor is a likely culprit...
SuperBeast
An enforcer for the Mopar Mafia!
#2273140 - 03/20/17 03:52 PM Re: 5.7 hemi misfire help [Re: keith airgrabber]
moparjim79 Offline
Loc: Central Pa
Just to clarify, was it actually backfiring? Or was there multiple momentary losses of power? The condition your describing sounds like 2 things. Yes, a crank sensor. Perhaps though, it threw a can code because the timing chain is about to $hit the bed as well.
#2273330 - 03/20/17 08:49 PM Re: 5.7 hemi misfire help [Re: keith airgrabber]
No backfires. Just skips of power loss. I changed the cam sensor and test drove it. Seems fine now. But I will have to see what happens yet. You know how these things go.
#2273349 - 03/20/17 09:15 PM Re: 5.7 hemi misfire help [Re: keith airgrabber]
WO23Coronet Offline
Loc: Canada
Same thing happened to my 05 Magnum RT, replaced the crank sensor and all fixed. Believe it's on the rear passenger side of block, you have to take the starter off to get to it
#2273542 - 03/21/17 08:27 AM Re: 5.7 hemi misfire help [Re: WO23Coronet]
moparjim79 Offline
Loc: Central Pa
Correct- I had an 05 neon with the same symptoms, crank sensor resolved the issue.
#2274762 - 03/23/17 11:10 AM Re: 5.7 hemi misfire help [Re: sycboi]
L.R Helbling Offline
Loc: Ottawa, Ontario
I agree. It is a somewhat easy fix and The part is fairly inexpensive. If I remember correctly it was $25 Canadian from RockAuto so much cheaper for you guys. The starter needs to be partially removed to put it on. Best thing to do is start with the cheapest fix first but looking at the DTC, it seems probable that it is the crankshaft position sensor.
#2276939 - 03/26/17 11:37 PM Re: 5.7 hemi misfire help [Re: L.R Helbling]
Changed the cam sensor and it did not help. Went ahead and changed out the crank sensor. All is well now no codes. Car drives normal again. Thanks for everyones input.
25,298 Registered Members
189,451 Topics
Boom! Wall meet Danika...
by rrbrucea
05/27/18 01:30 PM
Electric fan placement for max cooling?
by Digger73
05/27/18 12:38 PM
Screws for Finish Panel
by b body idiot
05/27/18 11:48 AM
What type of anodizing is on '69 Charger rocker moldings?
by Dixie
05/27/18 10:25 AM
