#2224498 - 12/31/16 11:15 PM Classic/Streetrods - Parts For Sale - 1st Quarter
moparts Offline
#2243342 - 01/29/17 10:35 AM Re: Classic/Streetrods - Parts For Sale - 1st Quarter [Re: moparts]
Joesixpack Offline
Loc: APACHE JUNCTION AZ
MADE IN THE USA DUAL POINT TUNE UP KIT
COPPER INSERT HD DELCO REMY DISTRIBUTOR CAP
NORS USA MADE HD RIVETED DELCO REMY ROTOR
SHURHIT USA MADE DUAL POINTS
KEM MADE IN USA WIRE STYLE CONDENSER
WILL FIT;
1951-1955 CHRYSLER HEMI V8 DUAL POINT
1952-1955 DESOTO HEMI V8 DUAL POINT
1953-1954-1955 DODGE HEMI V8 DUAL POINT
1955 PLYMOUTH V8 HEMI DUAL POINT$45
cowgerwilliam035@gmail.com
Edited by Joesixpack (01/29/17 10:36 AM)
#2243351 - 01/29/17 10:47 AM Re: Classic/Streetrods - Parts For Sale - 1st Quarter [Re: Joesixpack]
Joesixpack Offline
2 USA MADE NORS REAR AXLE SEALS,OUTER,NATIONAL 6241
2 USA MADE NORS REAR AXLE GREASE SEALS,INNER,NATIONAL 50776,
2 USA MADE NORS FRONT WHEEL GREASE SEALS,NATIONAL 6456
WILL FIT;
1949-1950-1951-1952-1953-1954 AND EARLY 1955 DODGE,PLYMOUTH&DESOTO$25 plus 7.00 small priority mail flat rate
Edited by Joesixpack (01/29/17 10:47 AM)
#2256582 - 02/20/17 11:34 AM 1930 Plymouth Frame [Re: moparts]
RTSrunner Offline
Loc: Pittsburgh,PA
I have a 1930 (as far as I can tell it is a 1930) Plymouth frame for sale.It is clean and unmolested,no cuts or chopped rails or supports.Only a few minor pits on the top of the rail,it even has some black paint remains on it.Great resto or rod frame. $1000.oo
PM here,text or call 412.4oo.0974 Thanks,RT
#2273197 - 03/20/17 05:10 PM Re: 1930 Plymouth Frame [Re: RTSrunner]
Joesixpack Offline
NOS 2084 080 POWER POINTS (IAZ-2040LS)
1959-1960-1961-1962-1963-1964-1965 CHRYSLER 361-383-413-426W$15
#2274077 - 03/22/17 12:28 AM 1958 Carter AFB 2641S Carburetor [Re: moparts]
stat5 Online   content
Loc: St. Paul, MN
For sale good used rebuildable core Carter AFB 2641s 4bbl carburetor with a date code A8. I think the date code translates to January of 1958.
Nothing is frozen on the carb throttle plates open smoothly and idle adjustment screws turn. I have not had this carburetor opened up. The only thing I could see as an issue with this carburetor is that it missing the choke rod and choke arm which I think should be able to source with a bit of effort. I don’t think these carburetors can with choke pulloffs because the mounting bosses appear to not be threaded.
Per my research this carburetor fits a 1958 Plymouth 318 most likely a Belvedere.
$225 plus shipping
PM me here on the board
Edited by stat5 (03/22/17 12:37 AM)
24,484 Registered Members
178,561 Topics
Anyone here near Colville, Washington?
by 300by500
22 minutes 6 seconds ago
Spark plug for 511 break in
by mopar dave
28 minutes 59 seconds ago
What's missing, charcoal canister?
by cnxt
Yesterday at 11:26 PM
Anyone into 1972 Olympic stuff ? (Germany)
by OzHemi
Yesterday at 11:20 PM
