MSD Parts
#2273166
03/20/17 06:32 PM
03/20/17 06:32 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Does anyone know if MSD will sell parts of a crank trigger kit.. I'm looking for the radius part and the 90* part that mounts to it.. here is a pic of the whole thing... I havent called yet.. just wondering if it would be a waste of time Thanks https://www.summitracing.com/parts/msd-8633
Re: MSD Parts
[Re: MR_P_BODY]
#2273174
03/20/17 06:44 PM
03/20/17 06:44 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
Yes they will, I called them and got the parts direct.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
Re: MSD Parts
[Re: MR_P_BODY]
#2273346
03/20/17 11:11 PM
03/20/17 11:11 PM
Bad340fish
Tulsa OK
Yes they will, I called them and got the parts direct. Thanks Clark.. I will call them tomorrow It was pretty reasonably priced, I bought the part that bolts to the block and an undrilled sensor mount and it was less than $100 if I remember right.
Re: MSD Parts
[Re: Bad340fish]
#2273456
03/21/17 01:39 AM
03/21/17 01:39 AM
MR_P_BODY
Yes they will, I called them and got the parts direct. Thanks Clark.. I will call them tomorrow It was pretty reasonably priced, I bought the part that bolts to the block and an undrilled sensor mount and it was less than $100 if I remember right. Is yours mounted on the pass side.. also do you \ have the P/Ns for those parts thanks
Re: MSD Parts
[Re: MR_P_BODY]
#2273575
03/21/17 11:26 AM
03/21/17 11:26 AM
Bad340fish
Tulsa OK
It is on the passenger side and I do not have the part numbers, sorry.
Re: MSD Parts
[Re: MR_P_BODY]
#2273680
03/21/17 02:21 PM
03/21/17 02:21 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Mr. P innovator West cells are really nice trigger mount.. Which is far more adjustable than MSDS unit
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
Re: MSD Parts
[Re: Bad340fish]
#2273701
03/21/17 03:01 PM
03/21/17 03:01 PM
MR_P_BODY
Clark.. do you have a decent pic of your trigger and the area around it.. I'm trying to see which side of the engine will work best.. looks like I have a bit more room on the drivers side.. my alt might be a bit close on the pass side so I'm looking at options... thanks EDIT Between MSD and Innovators West it looks like I can mount to either side of the engine..
Re: MSD Parts
[Re: Bad340fish]
#2273735
03/21/17 04:00 PM
03/21/17 04:00 PM
MR_P_BODY
Thanks.. looks like I will be playing with this to see which side will clear better.. the angle of my belt might be to low to clear the sensor its self.. but I will see... is there any issue with the sensor being to close to the alt and picking up noise through the sensor
Re: MSD Parts
[Re: MR_P_BODY]
#2273743
03/21/17 04:09 PM
03/21/17 04:09 PM
Bad340fish
Tulsa OK
My setup has a shielded wire and the noise has not been an issue. It is also a digital signal so it is less susceptible to interference.
Re: MSD Parts
[Re: Bad340fish]
#2273746
03/21/17 04:11 PM
03/21/17 04:11 PM
MR_P_BODY
My setup has a shielded wire and the noise has not been an issue. It is also a digital signal so it is less susceptible to interference. Thanks I talked with MSD and got the P/N for the 2 parts I will need IF I go with the pass side of the engine
