6.1 cam degreeing-in a 5.7
#2269111
03/14/17 01:53 AM
03/14/17 01:53 AM
Posts: 1,874 Pittsburgh,PA
RTSrunner
Pittsburgh,PA
I know it's been asked before about putting a 6.1 cam in a 5.7,I've asked myself.What is the general consensus as to what degree of advance it should be installed at? I've read 4,6 and 8 degrees,guessing it differs to application.Mine will be in an ,04 Durango and in an otherwise stock engine.I started to gather parts to rebuild my blown up 5.7 in my Durango,but found a new Mopar long block that had a 6.1 cam installed,but with the OE chain.I plan on using a Crower or Comp Cams adjustable set to be able to degree the cam. Thanks for any advice~RT
Re: 6.1 cam degreeing-in a 5.7
[Re: RTSrunner]
#2272670
03/19/17 11:56 PM
03/19/17 11:56 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I put a 6.1 cam in my 5.7, but I just installed it straight up. am I in for problems? I never heard anything about advancing it. I haven't started the motor yet, but it is installed.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: RTSrunner]
#2278078
03/28/17 11:50 PM
03/28/17 11:50 PM
rattler
Crofton, Ky.
Can you just advance the timing with offset keys ( if so, who has them?). Or do I need a high dollar adjustable timing sets?
[Re: RTSrunner]
#2512073
06/23/18 10:18 AM
06/23/18 10:18 AM
Posts: 1,462 Mrytle Beach SC
johnscudashop
Mrytle Beach SC
What was the conclusion on this... What did you end up doing. I have a 04 5.7 with VVT pistons eagle heads and a 6.1 cam. Im putting it in a 78 D100 with a stockish 727 and 323 gear... Im thinking advancing it also, but the question how far...According to the Larry Shepard g3 hemi engine book,A stock 6.1 cam has a 108 deg centerline and a eagle 5.7 cam is around 114 deg
[Re: RTSrunner]
#2512757
06/24/18 09:29 PM
06/24/18 09:29 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
John, degree cam and find out where it is. I rarely trust books. If it ends up where WO23 says, you will need to do something
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: WO23Coronet]
#2517377
07/04/18 11:38 AM
07/04/18 11:38 AM
johnscudashop
Mrytle Beach SC
The Cam was sitting at 121.5 ICL at tdc . this is a 04 5.7 with 09 Eagle 5.7 pistons and eagle heads.. 8 degrees from the 121.5 figure would be 113.5 ICL....Just out of curiousity I advanced it one tooth and put the ICL at 107.5.. Got to be a what to move it and even if I do, I will have to check the intake valve to piston clearance . At this point before I go further, I am wondering if its even worth it or find a cam with different specs.. Anyone one here got any opinions on this
[Re: johnscudashop]
#2517967
07/05/18 02:37 PM
07/05/18 02:37 PM
dogdays
So the Larry Shepard-written book is WRONG. Surprise, surprise!
He's the guy who told us about the "thinwall" late blocks.
He's the guy who told us that all we needed to choose a camshaft was the lift because we were too stupid to understand 0.050 lift duration.
He gives engineers a bad name. Yet he still keeps getting published. He's like the writer who calculated the ET for a 1.000G acceleration from start line to finish line and came up with the quickest ET possible. I don't remember what it was, but probably hundreds of thousands of quicker ETs have been run.
End of rant.
R.
[Re: RTSrunner]
#2518446
07/06/18 03:22 PM
07/06/18 03:22 PM
sixpackgut
Charleston
This site blows. Every time i try to post a picture it doesnt work. Anyway IC 121. Bump it a tooth is 107. Perfect
