Re: 5.7 hemi misfire help
[Re: keith airgrabber]
#2272864
03/20/17 11:17 AM
03/20/17 11:17 AM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
Most likely it's the crankshaft position sensor. I've heard it can be several different things, but the Crank sensor is a likely culprit...
SuperBeast
An enforcer for the Mopar Mafia!
[Re: WO23Coronet]
#2273542
03/21/17 10:27 AM
03/21/17 10:27 AM
Posts: 1,395 Central Pa
moparjim79
Central Pa
Same thing happened to my 05 Magnum RT, replaced the crank sensor and all fixed. Believe it's on the rear passenger side of block, you have to take the starter off to get to it Correct- I had an 05 neon with the same symptoms, crank sensor resolved the issue.
[Re: sycboi]
#2274762
03/23/17 01:10 PM
03/23/17 01:10 PM
Posts: 381 Ottawa, Ontario
L.R Helbling
Ottawa, Ontario
Most likely it's the crankshaft position sensor. I've heard it can be several different things, but the Crank sensor is a likely culprit... I agree. It is a somewhat easy fix and The part is fairly inexpensive. If I remember correctly it was $25 Canadian from RockAuto so much cheaper for you guys. The starter needs to be partially removed to put it on. Best thing to do is start with the cheapest fix first but looking at the DTC, it seems probable that it is the crankshaft position sensor.
