Re: Anyone using a diablo Intune on an RT ram
[Re: stumpy]
#2273012
03/20/17 02:31 PM
03/20/17 02:31 PM
Posts: 5,999 Salem
Grizzly
Moparts Proctologist
Salem
Stumpy, none of that sh1t works, I thought you knew that? What is that like 3 grand for all of it? Will it amount to 15hp? The hot-air kit will just take it away and fill your motor with dirt for good measure.
The 5.7 from the Factory is as perfectly tuned as it comes. In '03 when Hot Rod went through the new engine with a fine-tooth comb it was pointed out the factory manifolds flow within 2% of a set of headers.
If you really must have headers, 6.1 factory headers come up all the time on Craigs List from some Meathead duped by some header advertising. Usually $100 can get them and they won't leak like that aftermarket crap.
The rest of your laundry list, well pick one at a time and just Google "Problems with ___________" and see what comes up, I don't have time waste on it, seen enough of it already.
Mo' Farts
Moderated by "tbagger".
[Re: stumpy]
#2273189
03/20/17 07:04 PM
03/20/17 07:04 PM
Posts: 12,008 Finally a HUSKER again
Moparnut426
On an 03, Id leave it alone. Might have the heads looked into, make sure the seats are all happy before ya beat on it. Might make sure the valve springs are upgraded, and I might make sure the exhaust manifolds are good, and not leaking from broken bolts.
The Diablo works great on the newer stuff, 13-17, they get in there and adjust fuel trims, timing, etc, etc, and can gain some serious HP and Tq, but unless your planning on a supercharger, or some power adder and need the PCM unlocked for a proper tune, the Diablo isn't worth the cost just as a hand held downloaded pre tune.
[Re: stumpy]
#2273411
03/21/17 12:44 AM
03/21/17 12:44 AM
Posts: 524 Mesa, AZ
Bill_T
Mesa, AZ
So.... I had rather a poor experience with diablo. The intune put my 2005 Ram into limp mode. Ended up buying a Drewtech Mongoose and subscribing to TechAuthority for the weekend to reflash and get it back into service. Due to the mods I had also invested in, decided to try an upgrade to the Trinity. Result - ABS light, and just took it to the dealer to fix. Lost the stomach for it after that. I ran the Superchips canned tunes without any issue whatsoever for years prior. YMMV, but I would find a shop that is familiar with the programmers to help you, at least your first go round on the truck (even if you have used the units before on other cars). I never had much luck finding one in Phoenix area, but Texas might be better....
This space not for rent.
[Re: Grizzly]
#2274645
03/23/17 05:01 AM
03/23/17 05:01 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Wow, what a bitter person. Headers don't make power.....Crikey, How many times do we have to hear people tell this lie? The cold air kits do work IF they draw air from outside the engine bay. I have 282,000 miles on a 2007 Ram that has had a FRAM kit. It runs clean and is still strong. The filter is an oiled K & N that I also hear people complain about but the engine keeps on running. I do agree though that some of the electronic tuning is not cost effective. The amount of money spent to gain 11 HP to the tire is steep. The traditional methods still work though: Less restriction of the incoming air and of the outgoing exhaust.
[Re: stumpy]
#2274671
03/23/17 10:00 AM
03/23/17 10:00 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
www.frptuning.comHe can write you a custom tune for your late model hemi. Way better than any chip or box He's even in Texas and loves tuning in person
**Photobucket sucks**
[Re: stumpy]
#2274966
03/23/17 07:36 PM
03/23/17 07:36 PM
Posts: 32,920 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
"Wow, what a bitter person. Headers don't make power.....Crikey, How many times do we have to hear people tell this lie? The cold air kits do work IF they draw air from outside the engine bay. I have 282,000 miles on a 2007 Ram that has had a FRAM kit. It runs clean and is still strong. The filter is an oiled K & N that I also hear people complain about but the engine keeps on running. I do agree though that some of the electronic tuning is not cost effective. The amount of money spent to gain 11 HP to the tire is steep. The traditional methods still work though: Less restriction of the incoming air and of the outgoing exhaust." I just hate it when I spend all this money and just go faster. What a waste.
