Re: CLEAR THE AIR ON SB HEAD CHOICE
[Re: A/MP]
#2275983
03/25/17 02:10 PM
03/25/17 02:10 PM
Posts: 20,158 Park Forest, IL
slantzilla
Park Forest, IL
No, it came from Bad340Fish. It just shows that if you ask questions and are in the right place at the right time, deals are out there.
[Re: A/MP]
#2275992
03/25/17 02:24 PM
03/25/17 02:24 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I wonder what the "I want to pick up the phone and order that same package of parts" price would be.
[Re: fast68plymouth]
#2275999
03/25/17 02:41 PM
03/25/17 02:41 PM
Posts: 20,147 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I wonder what the "I want to pick up the phone and order that same package of parts" price would be. Ohhhh boy!!!!!!!!!! Me too. LOL. Or the non Friends cost on some of these W9 heads.
[Re: A/MP]
#2276011
03/25/17 03:03 PM
03/25/17 03:03 PM
fast68plymouth
So. Burlington, Vt.
It's a very rare occurance for me to get a phone call from a potential customer where the build plan for the motor has a projected time frame spanning several years.
Usually, they want to know how much, and how soon can I have it?
I don't even try and stay abreast of who has, or where someone might find heads that are no longer produced, or what they cost.
If someone is interested in using head packages built around components that are no longer produced....... I let them do their own homework and price negotiating.
So, from my perspective, I only recommend parts that are "readily available" to anyone, and where there are reasonable quantities available.
[Re: RAMM]
#2276015
03/25/17 03:08 PM
03/25/17 03:08 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
6k are you kidding me where are you coming up with 6k rockers 1400 intake 350 valves 400 no whereclose to 6k I think MattW is probably dead on. First, you purchase the heads, then you have them ported and flowed right? Because I've always been told they are ueseless as cast. So what is my bill from Brett Miller or someone when I get them back assembled and ready to bolt on. I'm assuming you would want him to do the intake too right? So now I've purchased an intake and had it flowed. Now I get rockers, valve covers, custom headers, and all the other w-9 specific bits. 6K probably wouldn't cover it all. MattW would know he has gone down this road. His castings were 1g each with no guides or seats but came CNC ported-thank god. Mr. P-body must not realize that these heads require almost 2k in rockers, W9 intake, W9 headers, You're also not going to put a Ferrea 5000 series valve in a head like this so there's $700 or so in good valves, $300-$400 retainers, $600 good PAC springs, the actual guides, seats, seals, guide installation, guide honing, seat installation, valve job, bowl/throat blending, flow testing (not a one time flow test either), intake porting, head resurfacing to get chambers the way you want. I could go on and on. W9's are bad to the bone for the small wedge but not for a real budget deal. J.Rob [/quote] Thx Jesse I did want to have to type it. LOL Mike I'm not saying YOU didn't do your heads for less. I believe you. Mine on the other hand were not cheap. Than again nothing is. I"LL SAY IT AGAIN. You want cheap a stock set of Apache G3 will flow the same as My CNC ported W9 heads for a lot less. Yes the have their drawbacks by what engines does not? To the original OP as stated before a set of cast iron will get the job done. Hell Phone Jesse and see what he has laying around, or what he can get you. Dollars is at 1.30 exchange so it maybe worth you call. Matt
#2276056
03/25/17 04:39 PM
03/25/17 04:39 PM
Posts: 1,048 The Great White North
RAMM
All of the things Dwayne mentions add up fast. Thermostat housing and plumbing I machined. Also the valley cover was necessary to machine. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: A/MP]
#2276108
03/25/17 06:36 PM
03/25/17 06:36 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
Hughes sells a full CNC port Edelbrock RPM set for 3K, then recommends better exhaust valves and milling to correct chamber volume at extra cost. This gets you a 199cc intake port.
Which is why I couldn't understand all the howling when BPE priced his new 205cc heads at 2125 bare. To me that's a comparable head at a competitive price.
I paid 2595 to the door for my AirWolf 220s in 2013 with beehive springs, lock and retainers specified for a .625 lift fast rate of lift solid flat tappet cam. I went this route because it would allow me re-use my headers, 1.5 Crane gold rockers, intake, and valve covers. Then Brian talked me into selling my M-1 and buying an Edelbrock Super Victor, and letting him whittle on it. so like most projects like this, another 500 I wasn't counting on...
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: A/MP]
#2276146
03/25/17 08:09 PM
03/25/17 08:09 PM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
A friend has a very well done set of W9 heads that flow over 400...with the ported intake and everything else needed he said it cost 10 grand Canadian for the top end. ( $7500 US )
A new iron curtain drawn across the 49th parallel
[Re: B1MAXX]
#2276441
03/26/17 01:09 PM
03/26/17 01:09 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
My choice w8s flat top on pump e85. ..5.60 at 3080lb..
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Silver68RT]
#2276449
03/26/17 01:22 PM
03/26/17 01:22 PM
Posts: 207 People's Republic of Mass.
Belvedere2
The W9's might be overkill (or budget kill) for me. What can you get out of a set of ported W2's on a pump gas 408? I've got 11 cars, so I have to kind of spread the funds out a little. The Dart's current 360 has pushed it to a 13.42 @ 100 mph best, but it's pretty tired now, hence the R-block purchase. I'd like to get it in the low 10's so I'd have a chance at qualifying for Street Machine Eliminator if I went for that class. To give you a general idea I have two W-2 engines; one pump gas 340 and one race 380. The 340 dynoed 410 and the 380 was 550. 340 used a .486 lift cam, the 380 was 670/630. The 340 had an old port job probably hurt more than helped. Lol. The 380 is unported but they are 48* heads. I believe to get the best out of regular heads you need a cam between 550 and 600 lift. Hope that helps.
[Re: B1MAXX]
#2276462
03/26/17 01:32 PM
03/26/17 01:32 PM
MoparBilly
Phoenix, AZ
I had to go back and verify that this truly was the post about a 12 second set-up recommendation...... B1MAXX... That was so two pages ago! We are evolving...or devolving, depending on your perspective.
[Re: WHITEDART]
#2276469
03/26/17 01:38 PM
03/26/17 01:38 PM
MoparBilly
Phoenix, AZ
My choice w8s flat top on pump e85. ..5.60 at 3080lb.. Umm, Shiloh. I just watched that video. From the time you let go of the trans-brake until you clicked it, the tachometer stayed in my "No-Go" zone. Geez!
[Re: A/MP]
#2276511
03/26/17 02:38 PM
03/26/17 02:38 PM
fast68plymouth
So. Burlington, Vt.
Sooooo, from the block on up, not including the carb(we'll say everything between the block and the carb)...... That would be more or less than 6k?
Impressive numbers!!
What kind of dyno? I'm not used to seeing the print outs in .1 second increments.
