Manual b body pushrod and A body MC for power brakes? #2270797
03/16/17 09:46 PM
03/16/17 09:46 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
Can i run a 73-76 A body MC for power brakes using the 69 B-body factory manual pushrod?
I have noticed that the MC hole diameter is a bit bigger and the pushrod ,even with a new rubber on it, does not enter there under pressure .
I don,t know if this could be dangerous or will not work properly.Once everything is installed does not seem that it can scape,but it is best to make sure.
Re: Manual b body pushrod and A body MC for power brakes? [Re: Coke] #2271172
03/17/17 02:30 PM
03/17/17 02:30 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
I'm using an "A" body dual master cylinder on my Polara front disk upgrade. Although mine is a non power unit I believe the pushrods are pretty much the same and the opening should be the same as well. That said, the easiest way I've found to get the pushrod to seat in the master cylinder is to put a little grease on the rubber and push it in. It might take a little effort but should slide in eventually.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Manual b body pushrod and A body MC for power brakes? [Re: Coke] #2276607
03/26/17 04:56 PM
03/26/17 04:56 PM
Vitoria, Spain
Coke Offline OP
Coke  Offline OP
Vitoria, Spain
I was in a mistake.
The pushrod keeps pressed in this mc too.
The grommet is loose until you press it with the pedal a couple of times.
Thanks.
