Re: 1 1/32 master cylinder an first.gen Viper calipers
[Re: Coke]
#2265471
03/08/17 10:36 AM
03/08/17 10:36 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
A quick look online and the master that came on the viper was 1 1/16" but that was also with power assist.
I would drop down to a 7/8" master and see how it feels.
**Photobucket sucks**
[Re: Coke]
#2266080
03/09/17 09:58 AM
03/09/17 09:58 AM
Posts: 340 Vitoria, Spain
Coke
Vitoria, Spain
Yes,that is what the sheet said.But as you said,does not work with manual brakes. What model did use 7/8 MC? I had found a cheaper dorman 15/16. Cast iron mc for 76'A bodies.The ports are 9/16-18 and 1/2-20. Are the same than the aluminium master cylinder? I ask this because i have seen that also were mopar master cilinders with 9/16"-20 threads..
[Re: Coke]
#2266683
03/10/17 11:29 AM
03/10/17 11:29 AM
70Cuda383
Marysville, O-H-I-O
I don't know if any came with a 7/8, you may have to find an aftermarket master from Wilwood, Baer, ssbc, etc.
If the 7/8 is too soft of a pedal or doesn't have enough stroke, then a 15/16 may fit the bill. The problem with all the brake calculations is that it's nearly impossible to calculate actual pedal feel while stopping the car, to know if it's what you want/like; and you end up trying a few different things until you find the perfect combo
[Re: Coke]
#2267330
03/11/17 12:33 PM
03/11/17 12:33 PM
Coke
Vitoria, Spain
searching on the web i have seen the 95' Lebaron uses a 7/8 MC.It uses very different port threads and i cant,t find plug and play adpters for them, so i would need to start fabricating lines, ordering fittings etc. Besides, i think that the piston back must to be machined to fit the stock pushrod.
I going to try a 15/16 first.If it does not work ,i will go for the 7/8.They are not expensive anyway.
If somebody knows were i could find a 9/16-20 female to 9/16-18 male brake adapter,it would be a big help.
Thanks.
[Re: Coke]
#2267925
03/12/17 11:49 AM
03/12/17 11:49 AM
70Cuda383
Marysville, O-H-I-O
Flaring brake lines is easy. Just cut the flare off, replace the tube nut and reflare
