5.7 Mini Starter #2265657
03/08/17 04:29 PM
03/08/17 04:29 PM
cbusters Offline OP
cbusters  Offline OP
I have read that there are "bosses" that have to be removed to run a mini starter on an early 5.7. There are two threaded areas on the lower right of this picture. Is this what is being referred to? If so, how much needs to be removed?
Re: 5.7 Mini Starter [Re: cbusters] #2265662
03/08/17 04:44 PM
03/08/17 04:44 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
Those are them, yes. Cutting them down even with the edge of the pan rail is a good start at making some mini starters fit...
SuperBeast
An enforcer for the Mopar Mafia!
Re: 5.7 Mini Starter [Re: cbusters] #2265684
03/08/17 06:00 PM
03/08/17 06:00 PM
cbusters Offline OP
cbusters  Offline OP
Anything special about doing it? The engine shop wants to do it before they build the motor. Cut-off wheel and 2" sander?
Re: 5.7 Mini Starter [Re: cbusters] #2265690
03/08/17 06:09 PM
03/08/17 06:09 PM
Norwalk, Ohio
sycboi Offline
sycboi  Offline
Norwalk, Ohio
That'd work perfectly. Shouldn't take more than 20 - 25 minutes to do a nice clean job...
SuperBeast
Re: 5.7 Mini Starter [Re: cbusters] #2265695
03/08/17 06:27 PM
03/08/17 06:27 PM
cbusters Offline OP
cbusters  Offline OP
Thanks, my first Hemi swap, lol.
