Re: 1971 'Cuda 340 K frame Correct or Not ?????
[Re: autoxcuda]
#2263976
03/05/17 10:09 PM
03/05/17 10:09 PM
Posts: 140 Akron, ohio
76orangewagon
Akron, ohio
Wow. Just when you think you've seen everything.
Yes that is a 69 or earlier k-frame. That probably is the factory ebody/70-72 bbody sway bar since the width look to fit the Ebody/70-72 bbody LCA's.
You can buy new reproduction sway bar bushing U-shaped brackets. Thank you, I just ordered new sway bar parts from Bill Rolik yesterday since the bushings and U shaped brackets were crushed that's when I started my Goggle search and realized something didn't look correct. I guess I'm looking for a correct 383052 K frame.
[Re: 76orangewagon]
#2263990
03/05/17 10:26 PM
03/05/17 10:26 PM
Posts: 200 Colorado
Bob J
Colorado
try Firm Feel for a reinforced K frame
07 Porsche C2 997.1 6spd DD and SCCA Solo II SS 68 Plymouth GTX Convert. 493cu Hotkiss Wilwood Classic air, Building for Solo II Cam 65 Chrysler 300 Convert. project 57 Desoto 2dr. Firesweep 392 Hemi,Wilwood Project with son 2003 Dodge Dakota R/T "DEAD"
[Re: 76orangewagon]
#2264006
03/05/17 10:41 PM
03/05/17 10:41 PM
Posts: 27,453 So Cal
autoxcuda
So Cal
You can buy new reproduction sway bar bushing U-shaped brackets. Thank you, I just ordered new sway bar parts from Bill Rolik yesterday since the bushings and U shaped brackets were crushed that's when I started my Goggle search and realized something didn't look correct. I guess I'm looking for a correct 383052 K frame. Any 70-74 ebody or 71-72 b-body V-8 kmember will interchange (not hemi). Some 74 ebody k-members have weird brackets near the motor mounts. And 440 and 440-6 k-members will have skid plates for their deeper oil pans. More info here: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/711060/k-member-id-question.html
[Re: autoxcuda]
#2264016
03/05/17 11:01 PM
03/05/17 11:01 PM
76orangewagon
Akron, ohio
You can buy new reproduction sway bar bushing U-shaped brackets. Thank you, I just ordered new sway bar parts from Bill Rolik yesterday since the bushings and U shaped brackets were crushed that's when I started my Goggle search and realized something didn't look correct. I guess I'm looking for a correct 383052 K frame. Any 70-74 ebody or 71-72 b-body V-8 kmember will interchange (not hemi). Some 74 ebody k-members have weird brackets near the motor mounts. And 440 and 440-6 k-members will have skid plates for their deeper oil pans. More info here: https://board.moparts.org/ubbthreads/ubbthreads.php/topics/711060/k-member-id-question.html Thanks again, So according to that thread it looks like my geometry is off also...great. Time to post that want ad. Looks like those parts from Bill Rolik will have to wait a while before they get used.
