Help needed to pick the right size m/c 4 manual brakes #2263532
03/05/17 02:31 AM
03/05/17 02:31 AM
GA
roadrunninMark Offline OP
GA
I don't have the right program it seems to run Feet's brake program, so I will ask you guys. Here is what I have installed in a 71 e body, auto (will be 42RH), 318 (going to rebuild close to junyard jewel power level (300+ hp)), power steering, and manual brakes (factory brake pedal for that car):
Front: 11 3/4" front disc upgrade from manual 4 wheel drum (followed mopar action upgrade, single piston pin factory style calipers)
Rear: 10" factory drums
Currently installed 1 1/8" aluminum m/c. I was going to go for hydroboost to use with the bigger m/c but figure I don't need it. Is this m/c too big and if so, what size should I use? I don't want to have to stand on the pedal to stop it and would like a nice "modern" braking action. Should I go with 15/16"?
Re: Help needed to pick the right size m/c 4 manual brakes [Re: roadrunninMark] #2263557
03/05/17 04:29 AM
03/05/17 04:29 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I know if your doing the 4 wheel disks you should run the 15/16" but i'm not sure since your keeping manual brakes on the rear, someone else here can comment about that. There's a huge brake thread here with all the math you need to calculate what your car needs.
Re: Help needed to pick the right size m/c 4 manual brakes [Re: roadrunninMark] #2263588
03/05/17 11:28 AM
03/05/17 11:28 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Stock 71 E body manual M/C is 1 1/32".
Don't be the exception.
Re: Help needed to pick the right size m/c 4 manual brakes [Re: roadrunninMark] #2264142
03/06/17 02:31 AM
03/06/17 02:31 AM
GA
GA
Do they make a 1" m/c? That would be right in the middle.
Re: Help needed to pick the right size m/c 4 manual brakes [Re: roadrunninMark] #2264149
03/06/17 02:54 AM
03/06/17 02:54 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I had the same brake setup before I tore my 'Cuda down with a 1-1/8". That bore is too large for that application.
I'd be looking at a 15/16" if not the stock 1-1/32".
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Help needed to pick the right size m/c 4 manual brakes [Re: roadrunninMark] #2264314
03/06/17 02:59 PM
03/06/17 02:59 PM
GA
GA
I think I will try the 15/16" one. This way if I upgrade the brakes to something bigger in the future, it will be good to go.
