727 question #226214
02/15/09 09:56 PM
02/15/09 09:56 PM
San Diego
formula S Offline OP
San Diego
I have a 727 out of a 4x4 with a transfer case bolted to the back of it. So my question is, is the out put shaft different than a passenger car 727?
Re: 727 question [Re: formula S] #226215
02/15/09 10:15 PM
02/15/09 10:15 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
Yes, it is a lot shorter.
Re: 727 question [Re: formula S] #226216
02/15/09 10:16 PM
02/15/09 10:16 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Yes. you would have to change the output shaft along with the tail housing.
Re: 727 question [Re: formula S] #226217
02/15/09 10:16 PM
02/15/09 10:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
According to the 727 book most trucks used numerous
length out put shafts, does your transfer case have
the drive shaft flanges on both sides for the driveshafts
if so I would say you need a car tail shaft and out
put shaft for a slip joint drive shaft
Re: 727 question [Re: formula S] #226218
02/16/09 12:24 AM
02/16/09 12:24 AM
San Diego
San Diego
Thanks everyone
