Wheels and Rims #2259822
02/26/17 02:39 PM
02/26/17 02:39 PM
Philadelphia, PA
GTXKARL Offline OP
GTXKARL  Offline OP
Philadelphia, PA
I have a 1970 Plymouth GTX and I need a spare rim. Could someone tell if a rim from a Dodge Dart from 1970 with disc breaks and big bolt pattern fit my GTX with disc breaks and a big bolt pattern? Thanks. luck
Working on cars teaches you patience... and every curse word imaginable.
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Wheels and Rims [Re: GTXKARL] #2259834
02/26/17 02:50 PM
02/26/17 02:50 PM
if the GTX has 14's then yes. If 15's the calipers (Budd?) MAY require 15's. Others will chime in. Your 70 dart SBP has been converted to BBP?
Re: Wheels and Rims [Re: GTXKARL] #2259837
02/26/17 02:52 PM
02/26/17 02:52 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If the bolt pattern is 5 on 4-1/2" then yes, it should fit.
A body cars, up to and including 1972, originally came with a 5 on 4" bolt pattern. If the Dart has been changed over to the larger pattern then should be ok.
