When most people associate a driveshaft as being a simple link between the transmission and rear end. Since so many fail to consider a driveshaft as a performance upgrade, most stray from spending the extra cash on properly selecting the driveshaft to fit their build’s needs. Too often people try to reuse or recut an old OEM driveshaft to keep costs to a minimum. What so many fail to understand is that the driveshaft isn’t just a simple link, it’s the central artery in your car, transferring every inch of torque from your transmission through your driveshaft, to the differential and finally, to the pavement.
Read the whole story at Mopar Connection HERE:
