Re: BB fuel pump push rod
[Re: Hangtowner]
#2254697
02/16/17 06:52 PM
02/16/17 06:52 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
Remove the cam to work on getting it out by eliminating the problem on the tip Are you sure it isn't oil sludge built up on the other end that you can't see I've had some that I needed to use a pry bar to force them out with sludge on them
[Re: Hangtowner]
#2254711
02/16/17 07:29 PM
02/16/17 07:29 PM
Posts: 2,843 Pattison Texas
CSK
Pattison Texas
pull the distributor out & you can see the end of the rod.
[Re: Hangtowner]
#2255356
02/18/17 02:41 AM
02/18/17 02:41 AM
Posts: 3,275 West Coast, USA
jbc426
West Coast, USA
They can be stubborn, but the above tips should make quick work of it.
There's a good sized oil feed passage to keep the pushrod oiled. A lot of guys remove the fuel pump pushrod, and use a block off plate to cover the fuel pump hole. This leaves a significant opening in that section of oil system.
I rarely hear anyone address this. Why?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Hangtowner]
#2255501
02/18/17 02:42 PM
02/18/17 02:42 PM
Posts: 1,315 Ohio
jlatessa
Ohio
I didn't realize the pushrod had an oil supply other than splash. We need to solve this ? as I'm almost ready to test our 512 without the rod.
I see the one vertical gallery on the schematic just before the right main oil gallery but it doesn't look like it is involved with the pushrod.
With no pushrod, if there were an opening at that point, it would be a big pressure/volume loss to the rest of the oiling system, save for the front cam bearing supply. I have never heard of this??
Input, experts?? Thanks,
Joe
[Re: jlatessa]
#2255533
02/18/17 04:21 PM
02/18/17 04:21 PM
Cab_Burge
I don't remember seeing any oil passage to any stock Mopar B/RB or Gen 2 Hemi fuel pump pushrod passages I'll look later today at two bare blocks, 383 and new World cast iron Hemi, that have in stock The number one main is oiled off the crossover oil galley from the oil pump boss in the front of the block that feeds the passenger side lifter galley, maybe that is what he is thinking of
[Re: Hangtowner]
#2255591
02/18/17 06:46 PM
02/18/17 06:46 PM
CSK
Pattison Texas
just looked at my 68 383 out of my Charger, no oil passage there.
[Re: Cab_Burge]
#2255882
02/19/17 04:51 AM
02/19/17 04:51 AM
jbc426
West Coast, USA
Well, that's probably why no one talks about it. Thanks guys.
