Page 3 of 6 1 2 3 4 5 6
Re: Progress [Re: 5280Dart] #2187116
10/31/16 11:38 PM
10/31/16 11:38 PM
tri-cities Washington/Denver, ...
5280Dart Offline OP
5280Dart  Offline OP
steering nearly completed.
Re: Progress [Re: 5280Dart] #2187324
11/01/16 12:53 PM
11/01/16 12:53 PM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
Thank you for posting. The information is very helpful and is greatly appreciated.
I can't wait to get cutting, ........now if I could only remember were I put everything! cool
Re: Progress [Re: 5280Dart] #2187461
11/01/16 04:08 PM
11/01/16 04:08 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Can you give some info on the steering couplings and shaft. I like that!
Re: Progress [Re: Greg55_99] #2187634
11/01/16 08:41 PM
11/01/16 08:41 PM
5280Dart Offline OP
5280Dart  Offline OP
The components were purchase from borgeson.com Starting from the rack and going towards the steering wheel....
I went with a polished stainless double u-joint 3/4"36 spline x DD at the steering rack, polished stainless 3/4" shaft, a 3/4" rod end for support of the shaft, then on to the polished stainless 3/4" DD x 3/4"36 spline single u-joint at the fire wall. I made a mounting plate at the fire wall to hold the carrier bearing which holds a 3/4" x 3.5" shaft with 36 splines on both ends, polished stainless 3/4" DD x 3/4" smooth bore single u-joint on the interior side of the fire wall, mating to a 3/4" solid round shaft that runs up toward the steering wheel thru the steering column. The top 9" of OEM steering shaft was pinned to the 3/4" shaft to allow the steering wheel to mount with factory splines and threads. There is a little trickery at the base of the steering column housing where I mounted another carrier bearing to support the shaft as it passed out of the column housing.
Re: Progress [Re: 5280Dart] #2203062
11/26/16 11:29 PM
11/26/16 11:29 PM
5280Dart Offline OP
5280Dart  Offline OP
Jeep TJ booster and master cylinder installed
Re: Progress [Re: 5280Dart] #2248194
02/06/17 12:43 AM
02/06/17 12:43 AM
5280Dart Offline OP
5280Dart  Offline OP
Header mock up has begun..
Re: Progress [Re: 5280Dart] #2248344
02/06/17 11:18 AM
02/06/17 11:18 AM
moparx Online content
moparx  Online Content
looks like a really tight fit on the drivers side threading the steering shaft through the tubes. very doable though, as i had to do the same thing on my humpback. just make sure you can easily remove the shaft for future reasons when necessary. on another note, [how's that for introducing a hijack ?] is it possible for you to measure the diameters of the crank, waterpump, air conditioning compressor, and alternator pulleys ? i am looking at ratios for comparison purposes on a thought i have had kicking around in my head for a while. yes, my thoughts can be dangerous at times and require more work than is deserved. thanks in advance !
beer
Re: Progress [Re: 5280Dart] #2248355
02/06/17 11:52 AM
02/06/17 11:52 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I was looking at your header mockup and thinking, why not just use Dakota headers it should clear. Then I realized "yeah, it's got a Hemi".
Nice work there.
Don't be the exception.
Re: Progress [Re: 5280Dart] #2248557
02/06/17 04:04 PM
02/06/17 04:04 PM
5280Dart Offline OP
5280Dart  Offline OP
Moparx, I will try to get some measurements for you this coming saturday.
Supercuda, I had hoped to use dakota headers, but no one offers gen III hemi headers for a first gen dakota. Also, I suspect I might have run into floor pan clearance issues, but not sure. They do offer headers for later gen dakota/hemi swaps for those interested.
Re: Progress [Re: 5280Dart] #2251319
02/10/17 10:56 PM
02/10/17 10:56 PM
5280Dart Offline OP
5280Dart  Offline OP
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2251439
02/11/17 02:38 AM
02/11/17 02:38 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Is there a height difference between the 6.1 and a 5.7 Hemi? The picture of the motor on the chassis with the body mounted, makes it appear the motor might be above the hood height. Are you anticipating hood clearance issues?
We have a 57 Dodge, stock chassis, we are planning on installing a 5.7 from a truck into. It is my understanding that the truck intake is taller then the car intake. I'm growing concern about hood clearance. Gene
Re: dodge dakota frame swap, custom coils or air bags needed [Re: poorboy] #2251447
02/11/17 02:59 AM
02/11/17 02:59 AM
5280Dart Offline OP
5280Dart  Offline OP
The Dakota front frame clip is responsible for the height of the engine. It is going to be close, but it will clear the hood. As for the truck engine being taller than the 6.1 intake height, I cant say for sure, but it seems unlikely. With a stock frame/chassis, you should have plenty of room.
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2251861
02/11/17 10:20 PM
02/11/17 10:20 PM
5280Dart Offline OP
5280Dart  Offline OP
Moparx:
Crank Pully: 6.5" dia.
Alternator: 2.375" dia
A/C: 5" dia
Powersteering: 4.875"dia
Water Pump: 4.375" dia
Idler pulley: 2.750" dia
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2252121
02/12/17 10:23 AM
02/12/17 10:23 AM
up thanks ! that info gives me some ratios of the components vs crank pulley. that will help me a bunch to determine some rpm spreads. thanks again !
beer
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2263414
03/04/17 08:55 PM
03/04/17 08:55 PM
5280Dart Offline OP
5280Dart  Offline OP
Header mock up completed...
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2263531
03/05/17 02:30 AM
03/05/17 02:30 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Are you going to build your own headers from a header kit, or have a set made someplace? Gene
Re: dodge dakota frame swap, custom coils or air bags needed [Re: poorboy] #2263539
03/05/17 02:51 AM
03/05/17 02:51 AM
5280Dart Offline OP
5280Dart  Offline OP
I don't own a TIG welder, and when I finally buy one, it will be capable of welding .250 wall tubing ($$$). I also don't own a band saw. Given the cost of obtaining these items, and the rate at which my build is eating away at my disposable income, I will be having GP headers fabricate the headers based on the mock up. http://www.gpheaders.com/
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2263578
03/05/17 10:34 AM
03/05/17 10:34 AM
AZ
Mike P Offline
Mike P  Offline
AZ
Very nice work. I might have missed it, but what are you using for a steering column?
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: dodge dakota frame swap, custom coils or air bags needed [Re: Mike P] #2263615
03/05/17 12:46 PM
03/05/17 12:46 PM
5280Dart Offline OP
5280Dart  Offline OP
I am using the factory column. I cut the length down, installed a bearing on the end of the cut down housing, and pinned a section of solid 3/4" dia. shaft to the remaining factory steering shaft. After the solid section passes thru the bearing installed at the firewall end of the housing, I have a u-joint installed to make the connecting to the bearing plate attached to the firewall.
Re: dodge dakota frame swap, custom coils or air bags needed [Re: 5280Dart] #2263657
03/05/17 01:48 PM
03/05/17 01:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Very impressive.
I like the way you mocked up those pipes with off the shelf stuff.
I probably will never build a set of headers, but I surely will be able to use a version of that for making my own dual exhaust systems.
Hope you don't mind me stealing that idea.
I have mechanical Aptitude.
I can screw up anything.
