#2251401 - 02/10/17 10:33 PM Summit racing four post lift?
Kidsixpack Offline
Loc: Detroit
Has anyone ever heard of or seen a four post lift that can also be used as a two post. From what I gather the ramps can be removed and the frame remains. Uses arms to lift the car like a two post. I can't find anything on their site.
KID
www.sixpacksuperbee.homestead.com
This pic. is before the resto.
V2 Hemi orange 69 1/2 Super Bee black buckets console 4spd radio delete.
1989 Turbo Trans Am
1987 Buick GN 11,000 miles
#2251508 - 02/11/17 08:39 AM Re: Summit racing four post lift? [Re: Kidsixpack]
peabodyracing Offline
Loc: Minnesota
News to me. Possible I'm sure but at what trouble and expense?
Just dragged home a 10 yr old 9K pd Bendpack 4 post. Been studying it a bit as I try and figure out how to get it off my car trailer. (seller was able to load it fully assembled onto the trailer for me, but was setup with some pretty heavy equipment)
Much of the lift mechanism is under (and attached to) the right side ramp. Even redesigning and relocating all that the ramps themselves are long and heavy!
As I stand there and look the mechanism over I'm reminded of force vectors from college. Someone had a good time figuring that all out for one of these.
Converting to an arm style lift would significantly change much of that.
Lead, follow or get the hell out of the way
#2251631 - 02/11/17 11:56 AM Re: Summit racing four post lift? [Re: peabodyracing]
TJP Online   content
Loc: Omaha Ne
heavy duty furniture dollies ?? (Think rental yard) and at least 4 buddies. shruggy popcorn
www.tandmautomotive-omaha.com
#2254147 - 02/15/17 03:37 PM Re: Summit racing four post lift? [Re: Kidsixpack]
Kidsixpack Offline
Loc: Detroit
I found some info on the lift. It's a dammar lift with a kit added to it. The kit has been discontinued for safety reasons.
Oh well the search for the perfect lift continues.
KID
1989 Turbo Trans Am
#2254223 - 02/15/17 06:07 PM Re: Summit racing four post lift? [Re: Kidsixpack]
70Cuda383 Offline
Loc: Marysville, O-H-I-O
The perfect lift is a 2 post with arms that swing enough to reach as wide as possible on the vehicle. The hobby shop on base had both and I was afraid of the 2 post. Always used the 4 post with the ramps.
Then I worked in a shop with a 2 post and I was impressed at how much better it was for access.
2-post for the win!
**Photobucket sucks**
#2254525 - 02/16/17 09:58 AM Re: Summit racing four post lift? [Re: peabodyracing]
wldgtx Offline
Loc: Clarkston, MI
When my wife and I recently moved to a new house I found myself in a pickle with how to move my new 4 post lift.
If you already have it on a trailer, the way we got ours down was with a cherry picker, one end at a time. The trick is to keep it balanced and make small adjustments as necessary. It was just the two of us and it went smooth as silk.
1968 GTX Hemi, 4 spd
1970 Challenger R/T SE
#2254977 - 02/17/17 09:44 AM Re: Summit racing four post lift? [Re: wldgtx]
Loc: Minnesota
TJP and WLDGTX thank you both for the input on unloading the 4 post from my car trailer.
I will be using both your suggestions. The layout of my building requires I remove the lift from the back end of the trailer. In order to do so, I have to get the front end up high enough to clear the trailer fenders as I move the lift 'back' on the trailer.
Sounds good in theory anyway. Thanks again.
25,383 Registered Members
190,972 Topics
Anybody ever use miller spot welders?
by 71sat440
07/20/18 07:50 PM
Forgive me father, for I have sinned.........
by SKR8PN
07/20/18 07:17 PM
First time front suspension issues...
by ksat
07/20/18 07:12 PM
Which rad cap
by dragon
07/20/18 06:29 PM
