Re: 440 compression check
[Re: 73bbroadrunner]
#2250624
02/09/17 08:56 PM
02/09/17 08:56 PM
RapidRobert
agreed, that is very high. It'd be nice if you had a borescope to see whats in there. My HF unit was not cheap but it has came in very handy/saved my bacon several times.
#2250703
02/09/17 11:06 PM
02/09/17 11:06 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If it has been sitting for a while, it's very possible the lifters are no longer pumped up, which makes the duration at the valve much shorter....... And the compression test will read high. If the 250psi had been observed just after the motor was run and warmed up, and you knew the gauge was accurate....... Then I'd say the cam was like a tooth off(advanced), or the motor is way over 10:1cr(as in waaaaaaaaaaay over).
[Re: BSB67]
#2250720
02/09/17 11:30 PM
02/09/17 11:30 PM
Posts: 1,235 Phoenix, AZ
Jjs72D
Deep in the closet
Deep in the closet
Phoenix, AZ
check the gauge, or try another gauge. Yeah, I agree. I've seen them be in error before. Has anyone ever seen an engine with these cylinder numbers run on even 93 octane unleaded? It seems to me an engine with 250psi would need over 100 octane to avoid knocking like 20 bill collectors at the door.
[Re: Jjs72D]
#2250822
02/10/17 01:54 AM
02/10/17 01:54 AM
RapidRobert
agreed, sumpin ain't right (& if it is, it is race gas city). Keep after it & keep us posted.
#2250998
02/10/17 01:29 PM
02/10/17 01:29 PM
Posts: 5,161 CT
GTX MATT
CT
That sounds like almost 100 PSI too much for that CR and cam, if you told me 150-175 I'd say it sounds right. That sounds like a 13.5:1 engine
#2251025
02/10/17 02:08 PM
02/10/17 02:08 PM
fast68plymouth
So. Burlington, Vt.
I don't know what kinds of parts the op has laying around, but if the motor has an adjustable valvetrain, or the op has some rockers kicking around, and some solid lifters..... You could pull two hyd lifters out, swap in two solids, adjust lash to about .003 lash, retest.
If it still tests stupid high(and you're absolutely sure the gauge is accurate.....then IMO, something needs to come apart to see what's what.
[Re: fast68plymouth]
#2251098
02/10/17 04:29 PM
02/10/17 04:29 PM
dogdays
I agree with Fast68.
You are doing the compression check right, with all the plugs out.
You say average. What is the spread? Have you gotten the same result on more than one cylinder?
R.
[Re: Jjs72D]
#2251386
02/11/17 01:09 AM
02/11/17 01:09 AM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Exhaust manifolds on an engine that cranks that high? It will like it.
#2251617
02/11/17 02:32 PM
02/11/17 02:32 PM
RapidRobert
906 heads that have been milled 30 and the block has been zero decked. If I was bored (& had plenty of time) which is the story of my life I would get a guestimate on the CC's of 906's milled 30 & an average HG thickness & the supposed zero deck & plug it in the the KB pistons calculator site (its a fun tool) & there there should be a site or chart somewhere on the SCR that would produce those kind of numbers then see what piston dome it would have to have to achieve that. that'd keep ya busy till you confirm with another gauge and or open it up (first I'd borrow a borescope). Keep us updated. EDIT At least I would see what dome/CC's would be needed to get 10:1 which is what they came up with & they did mention zero deck so likely they did measure everything.
#2251699
02/11/17 04:51 PM
02/11/17 04:51 PM
fast68plymouth
So. Burlington, Vt.
Just for comparison, some of the "better" FAST type builds I've been involved with pump around 240-250 and more. Those are 14:1+ compression with very fast rate solid roller cams.
Russ, did you ever check the cranking pressure on your 505?
My friends stock eliminator motor is 205-210, and my 383 was around 200 the way it was in the car. Lowered the cr from just under 11:1 to 9.7:1, and went from a 106lsa cam to a wide lsa cam with a later closing point and the cranking pressure dropped to 155.
#2251734
02/11/17 05:58 PM
02/11/17 05:58 PM
fast68plymouth
So. Burlington, Vt.
I played around with the Wallace cranking compression calculator.
It seems "highly unlikely" the motor is 10:1cr with the 484 cam, cranking 240+ psi...... Or the gauge is wrong(or maybe a little of both).
A 10:1 446 with the 484 cam installed at 104 should pump 156psi at zero feet elevation. Assuming the duration is actually "284", and a 104 c/l, the intake closing point is 66abtc.
Changing that number to "0", only moves the needle to 212psi. Changing the cr to 11:1 with the closing point still at "0" shows 240psi.
Assuming the cam is installed correctly; 14:1cr shows 237psi 14.5:1cr shows 248psi
I also plugged in the numbers from one of the FAST motors that pumped high, and it showed 240psi.
At this point, the gauge is still suspect in my mind.
#2251967
02/12/17 12:30 AM
02/12/17 12:30 AM
BSB67
Prospect, PA
Lash @ 0.025 = 190 - 195 psi Lash @ 0.014 = 175 - 180 psi. 10.8:1 CR.
#2252114
02/12/17 09:43 AM
02/12/17 09:43 AM
BSB67
Prospect, PA
But probably have an actual intake closing point of 78° to 80° ABDC. I think there is a lot of merit in the bled down lifter theory. Always kinda questioned getting an accurate compression test with today's hyd. lifters in general.
#2252269
02/12/17 02:31 PM
02/12/17 02:31 PM
fast68plymouth
So. Burlington, Vt.
Using the Wallace calculator, even assuming the valve is closed for the full 180deg of the compression stroke(which is saying the lifter bleed down makes the cam 132deg shorter), it still only showed 212psi. Even with the lifters fully collapsed, I'm not sure the intake closing point would change by 66deg.
I'm pretty confident the lifters are at least partially collapsed, but not enough to add 100psi to the compression test.
I think there is a good chance the gauge is reading a little happy.
#2258051
02/23/17 02:03 AM
02/23/17 02:03 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Just got engine running. I ran it for a few minutes then checked compression. It was at 195psi average on all cylinders.Turns out fast68plymouth was right on lifter theory. Thanks again. So you think that everyone else was an idiot ?
#2258059
02/23/17 02:25 AM
02/23/17 02:25 AM
RapidRobert
I missed something, If you dont mind, what made the psi reading come down from 250 to 195? I did not grasp the lifter post.
#2258286
02/23/17 07:14 PM
02/23/17 07:14 PM
fast68plymouth
So. Burlington, Vt.
Just got engine running. I ran it for a few minutes then checked compression. It was at 195psi average on all cylinders.Turns out fast68plymouth was right on lifter theory. Thanks again. I've actually been right about a few engine related issues once or twice before Glad it seems like it's worked out for you.
#2258333
02/23/17 09:18 PM
02/23/17 09:18 PM
RapidRobert
I've actually been right about a few engine related issues once or twice before We noticed (& are appreciative).
#2258345
02/23/17 09:28 PM
02/23/17 09:28 PM
Posts: 3,069 Michigan
A727Tflite
Fast68 - please check for a PM from me.
