Hood Clearance Question
#225042
02/14/09 09:21 PM
02/14/09 09:21 PM
Posts: 6,295 U.S.
moparniac
U.S.
What would you rather do? mill the indy 440-3 intake down or lower the motor some.... I need to go down about 3/8ths
thx
Mopar Performance
Re: Hood Clearance Question
[Re: moparniac]
#225044
02/14/09 11:09 PM
02/14/09 11:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
thx
If your contacting now... you need ALOT more than 3/8"
[Re: moparniac]
#225048
02/15/09 10:49 AM
02/15/09 10:49 AM
MR_P_BODY
I am guessing that you mean from the top of your air cleaner... if you have enough air filter that the engine can breathe then all you need is JUST clear (if you dont have any frame twist) a 1/4 " should work
[Re: B1Fish540]
#225053
02/15/09 03:56 PM
02/15/09 03:56 PM
Posts: 6,295 U.S.
moparniac
U.S.
already have a dropped base setup....
Mopar Performance
[Re: moparniac]
#225054
02/15/09 04:37 PM
02/15/09 04:37 PM
MR_P_BODY
Probably the easiest way would be to put 4.. 1/2" spacers between the frame and K-member
what kind of affect will that have on the auto tranny?
Well if the trans has a rubber mount I would unbolt the motor mounts and lower the K then look to see if there is any angle at the motor mounts when you bolt then back up, if there is any angle change then add a shim to the motor mounts. Basically you would be pivoting the engine down from the trans mount forward to the motor mounts. The tailshaft will raise up on the ratio of difference between the 2 points
