Hood Clearance Question #225042
02/14/09 09:21 PM
02/14/09 09:21 PM
U.S.
moparniac Offline OP
U.S.
What would you rather do? mill the indy 440-3 intake down or lower the motor some.... I need to go down about 3/8ths
thx
Mopar Performance
Re: Hood Clearance Question [Re: moparniac] #225043
02/14/09 11:02 PM
02/14/09 11:02 PM
Ortonville, MI
RoadRnnr69 Offline
Keyster
RoadRnnr69  Offline
Keyster
Ortonville, MI
How much clearance will the 3/8 give you?
I had 1 inch and my carb hit the hood. I ended up chaining the motor down and bought a six pack hood from mmissle.
Re: Hood Clearance Question [Re: moparniac] #225044
02/14/09 11:09 PM
02/14/09 11:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
thx
If your contacting now... you need ALOT more than 3/8"
Re: Hood Clearance Question [Re: moparniac] #225045
02/15/09 12:03 AM
02/15/09 12:03 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Put a scoop on that beoch.......you`ll need the cool air anyhow.
Re: Hood Clearance Question [Re: Thumperdart] #225046
02/15/09 08:13 AM
02/15/09 08:13 AM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I had a little more than 1" between the top of the carbs and my scoop. So I built a 6 pack style aircleaner that sits down over the carbs. Now I have more aircleaner surface area and it looks neat also.
Re: Hood Clearance Question [Re: MR_P_BODY] #225047
02/15/09 10:27 AM
02/15/09 10:27 AM
U.S.
U.S.
thx
I already have a tA hood........ it just barely and i mean barely touched bfore and I have solid motor mounts.... this new setup is only .25 taller so 3/8's will have no rub.....
but what way would you rather go.... will milling the intake affect performance..
Mopar Performance
Re: Hood Clearance Question [Re: moparniac] #225048
02/15/09 10:49 AM
02/15/09 10:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I am guessing that you mean from the top of your
air cleaner... if you have enough air filter that
the engine can breathe then all you need is JUST clear
(if you dont have any frame twist) a 1/4 " should work
Re: Hood Clearance Question [Re: MR_P_BODY] #225049
02/15/09 10:53 AM
02/15/09 10:53 AM
U.S.
U.S.
but when it just"barley" touch it mad a spider cirle crack in the area about the size of a 1/2 dollar... so will milling the intake 3/8's hurt performance or lower it via the k member
Mopar Performance
Re: Hood Clearance Question [Re: moparniac] #225050
02/15/09 11:18 AM
02/15/09 11:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Probably the easiest way would be to put 4.. 1/2"
spacers between the frame and K-member
Re: Hood Clearance Question [Re: MR_P_BODY] #225051
02/15/09 01:48 PM
02/15/09 01:48 PM
U.S.
U.S.
what kind of affect will that have on the auto tranny?
Mopar Performance
Re: Hood Clearance Question [Re: moparniac] #225052
02/15/09 02:16 PM
02/15/09 02:16 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Have you considered a drop base air cleaner, maybe you already have one. If so i would use a diffrnt intake, seems like it would be better than ruining a new intake(no resale value).
Re: Hood Clearance Question [Re: B1Fish540] #225053
02/15/09 03:56 PM
02/15/09 03:56 PM
U.S.
U.S.
already have a dropped base setup....
Mopar Performance
Re: Hood Clearance Question [Re: moparniac] #225054
02/15/09 04:37 PM
02/15/09 04:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well if the trans has a rubber mount I would unbolt
the motor mounts and lower the K then look to see if
there is any angle at the motor mounts when you bolt
then back up, if there is any angle change then add
a shim to the motor mounts. Basically you would be
pivoting the engine down from the trans mount forward
to the motor mounts. The tailshaft will raise up on
the ratio of difference between the 2 points
