Re: Lash caps stuck [Re: Bigbeep] #224995
02/15/09 12:11 PM
02/15/09 12:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use to do the string thing but as I wanted to hurry
things up I quit using it and never ran into a issue
Re: Lash caps stuck [Re: MR_P_BODY] #224996
02/15/09 12:30 PM
02/15/09 12:30 PM
nc
E
emarine01 Offline OP
E
nc
Hey all , thanks for all the input , we got the caps off, with some major heat , I think when we were messing with cam lash we went too much on the intake clearance +.015 too see how the engine changed with different cam timing, made 2 passes and must have beat the caps in, something to think about for the next time , will order new caps & locks and have at it again, THANKS!!
Re: Lash caps stuck [Re: emarine01] #224997
02/15/09 12:46 PM
02/15/09 12:46 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i bet it smoke pritty bad.what did you use to het it with?
Re: Lash caps stuck [Re: emarine01] #224998
02/15/09 12:49 PM
02/15/09 12:49 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I would have pulled the heads off before I put torch? near my valves
and springs.......but, I've been accused of overcomplicating things. If you
used a torch, I'd be concerned about ruining the valve springs in particular.
Re: Lash caps stuck [Re: S/ST 3040] #224999
02/15/09 01:03 PM
02/15/09 01:03 PM
nc
E
E
nc
I used map gas with a pin point tip , I put vise grips on the retainer for a heat sink but I needed a lot of heat to get it apart , I have questions about the springs too , I still am sitting on the fence for a cam change so when I finaly come up with a cam I will change out all the springs too , I have a test & tune next weekend , I was hoping to test out rear end set up but now I am not sure if I want to run , its a murfs law thing , I put a lot of heat on it?
