Pushrod Checker #224643
02/14/09 04:19 PM
02/14/09 04:19 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
I am getting ready to order a pushrod checker. I see they come in different ranges. This is for a Lowdeck big block with B1 heads and a roller cam.
What length should I get???
Re: Pushrod Checker [Re: joshking440] #224644
02/14/09 04:24 PM
02/14/09 04:24 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Jesel has the best one I have ever used. I didn't like the Comp one. The way the threads are made, and no provision for a lock nut to keep those 3 threads per inch moving as little LOL. The Jesel unit is a 3-4 peice unit that can range from a lawn-mower to a Hemi. It came free with a purchase of those Cheap rocker kits
Re: Pushrod Checker [Re: joshking440] #224645
02/14/09 04:38 PM
02/14/09 04:38 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
You want one with a range of 8.575" long. That's the stock lo deck pushrod length for 383 and 400s.
Re: Pushrod Checker [Re: Challenger 1] #224646
02/14/09 04:39 PM
02/14/09 04:39 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
thanks challenger1!!!
Re: Pushrod Checker [Re: joshking440] #224647
02/14/09 05:31 PM
02/14/09 05:31 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
If you want to do it on the cheep use a collapsable radio antenna, insert it ,extend it out, mark it with a sharpie, take it out and measure it. It will be the same as a boughten one.
Re: Pushrod Checker [Re: rowin4] #224648
02/14/09 05:38 PM
02/14/09 05:38 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
I have the Comp Cams one. As said, there is no lock nut to set length but I just tape it. Good for 383/400 length needed as this is what I used it for. Just
Re: Pushrod Checker [Re: BELVEDERE67] #224649
02/14/09 05:59 PM
02/14/09 05:59 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Take a stock pushrod, cut about 1.5" out of the middle, tap both ends with a 1/4-28 tap use a 2.5" lenght of 1/4-28 all-thread & two nuts.....You now have a pushrod checker...
Re: Pushrod Checker [Re: 1_WILD_RT] #224650
02/14/09 07:58 PM
02/14/09 07:58 PM
Indy
Lunch is on me!
Lunch is on me!
Indy
I needed a cup type so i bought the one trick flow makes... we will se how it works!!!
if any one needs to borrow it when im finished just let me know!!!
Re: Pushrod Checker [Re: 1_WILD_RT] #224651
02/14/09 08:06 PM
02/14/09 08:06 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
that's what i've done only i used a smith brothers that a chipped cup on one end thought it didn't affect the measurement
Re: Pushrod Checker [Re: joshking440] #224652
02/14/09 08:31 PM
02/14/09 08:31 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I prefer to use a ball/ball type rod for that measurment as it's pretty easy to hold it centered on the adjuster ball for the measurment & you need to measure the length from the bottom of the cup to the ball tip of the pushrod...
Re: Pushrod Checker [Re: 1_WILD_RT] #224653
02/14/09 10:54 PM
02/14/09 10:54 PM
jamesc Offline
jamesc  Offline
what they want to know is the effective length. you can use a ball/cup PR then drop a 5/16 steel ball in the cup measure the length with the ball in the cup then subtract .313 from that measurment to get the effective lenght.
