Help with aluminum rod torque spec #224637
02/14/09 04:09 PM
02/14/09 04:09 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I have a set of C&A aluminum rods with c&s 3000 rod bolts. Does anyone know what to torque them to? Apparently they are no longer in business to ask. The rods have a blind hole so can't do a stretch value.
Re: Help with aluminum rod torque spec [Re: mac56] #224638
02/14/09 05:45 PM
02/14/09 05:45 PM
Dillsburg, PA
mrsmallblock Offline
Dillsburg, PA
i think they are 7/16 bolts? If they are, its 70 ft. lbs. if they are 3/8, its 55 ft. lbs.
Howard
Re: Help with aluminum rod torque spec [Re: mrsmallblock] #224639
02/14/09 06:54 PM
02/14/09 06:54 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Howard
Yes I believe they are 7/16 bolts.
Thanks Howard
Re: Help with aluminum rod torque spec [Re: mac56] #224640
02/14/09 07:01 PM
02/14/09 07:01 PM
it depends on the series of rod as well as the bolt diameter and length. the above mentioned number may be correct, i don't know, but i'd want to be sure if i were you. i have some CA rods that take 90 ft. lbs. post more info about what you have and i'll see what i can find for you.
Re: Help with aluminum rod torque spec #224641
02/14/09 07:26 PM
02/14/09 07:26 PM
SE Michigan
TS3303 Offline
TS3303  Offline
SE Michigan
Whats important is to find what they were torqued at for final sizing. It won't do any good to torque them to any given spec if the bores are out of round there. If they are 7/16 torque them to 70-75 and measure the bore to check for roundness. Also make sure everything is at room temperature before starting. Adjust the torque accordingly as long as it's in the window for that fastener other wise they need to be resized at the desired torque.
Re: Help with aluminum rod torque spec #224642
02/14/09 10:39 PM
02/14/09 10:39 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Dram the only numbers I can see are 150 forged into the side of the cap and j188 stamped on the cap. 7/16 bolt
