Re: Which rear gear ratio?
[Re: Dr Dave]
#2245915
02/02/17 02:37 PM
02/02/17 02:37 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
4.10 is too deep for that car. The 2.87 first gear would be incredibly short with that rear.
You'll be fine with 3.73 gears.
We put a Tremec in a car with 3.54s and it liked 70 mph more than 60 mph in 5th gear.
[Re: Dr Dave]
#2245993
02/02/17 05:06 PM
02/02/17 05:06 PM
Posts: 43,119 Bend,OR USA
Cab_Burge
On your deal I would opt for the 3.91 I ran from 3.73 to 4.30 in my old pump gas Duster, it ran almost the same ET(10.30s) and MPH(127.) in the 1/4 mile at Woodburn. It seemed like it spent more time in high gear with the 3.73 but it ran almost the same The stick tranny with the O.D. should still hook and book with the proper starting line RPM at the drags It won't be easy to get it correct on the first pass but it is doable with some testing You can spin or bog on the starting line, your right foot will control that BTW, Yukon makes a 3.73 gear set for the 741 center section Those are the ones I used in my car
[Re: Dr Dave]
#2246103
02/02/17 08:42 PM
02/02/17 08:42 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
Dr Dave, as you can see the recommended gear ratios are all over the place. Why don't you decide for yourself? You can make the RPM calculator work for you like this:
1. Pick a rear end gear ratio to calculate on, say 4.10 for example.
2. Multiply that number by your overdrive ratio to get an "effective rear end gear ratio". In this case, 4.10 x 0.64 = 2.624
3. Use the standard RPM calculator to see what your rpm's would be with your tire diameter.
FYI - You can do the same sort of thing to get a feel for what your "shift point" would be in each gear at a reasonable rpm too. For example, with the same 4.10 gears and a 2.87 1st trans. gear you'd calculate like this:
a) 4.10 x 2.87 = 11.767 "effective gear ratio in 1st gear with 4.10's"
b) using your tire size, you can calculate a mph at a given rpm, say a 3000 rpm target shift point for daily driving, and see how many mph's you'd be going before you had to shift.
c) repeat the above with your other trans. gear ratios with a "target shift rpm" (like I just used 3000rpm) for the other gears to see how fast you'd be going in the other gears too.
Hope This Helps!
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Dr Dave]
#2246214
02/02/17 11:45 PM
02/02/17 11:45 PM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
I don't know if going to a 3.55 from a 3.23 is worth the time and effort. Thoughts? I've done it twice, it's noticeable, but yea, you could argue not worth the trouble.
[Re: dogdays]
#2246812
02/03/17 09:20 PM
02/03/17 09:20 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
So you have a 2.87 First gear. For years I have used an overall ratio of 10:1 for the First gear, as a calculation goal. 10 / 2.87 = 3.48. This is good advice. Multiply the trans ratio and the rear ratio. Take the tire height into consideratio and make a choice. Too low of a 1st gear is like having a truck with bull low.
[Re: Dr Dave]
#2247019
02/04/17 02:41 AM
02/04/17 02:41 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
For a street car that's not after every last tenth of ET, I like higher gear sets. I also don't mind a short smoke show 1st gear. Right foot input will control that on the street anyway. Stop and go traffic? That short gear will be happier on the clutch.
I had a TKO with .64 OD. I hated having RPM so low that 5th gear was useless below 65 mph. I went 4.56 and loved it. Tire frying through 3rd if I wanted to, yet cruise the highway at 70 mph at 2400 RPM.
**Photobucket sucks**
[Re: Jjs72D]
#2247062
02/04/17 05:58 AM
02/04/17 05:58 AM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I'm surprised nobody has mentioned that all factory 426 Hemi cars used the Dana when the 4 speed was used. You are now using an engine 102 cubes bigger with a smaller axle than stock? I am a little surprised at that, too. But, then I suppose he will be using a Radial T/A type tire that is more for show than grip and that should keep the 8.75" OK for now.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Dr Dave]
#2247095
02/04/17 11:26 AM
02/04/17 11:26 AM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
I have 3.23's in it now. There is plenty of torque to pull that gear but thought a steeper gear would optimize the package. With a big HEMI you are going to murder 27" tires on the street with any gear ratio. A gear set numerically higher than what you currently have will most likely make driving the car exponentially more exciting.
It seems like quite a few people have been surprised by similar ET's when they went up or down in rear end ratio either way.
I think this sums it up very well. The car will not be any faster or et any better with a gear change. First gear will be crisper, but other than that, the only difference is what gear you choose to be in. I did notice that you used the word "optimize", probably not by accident. So if you don't like the engine rpm when you are cruising down the freeway (i.e. it is too low) then a numerically higher gear ratio make good sense. To determine your final OD engine rpm simply put your information into your favorite online calculator, then multiply the rpm by the OD ratio, i.e. 0.64.
[Re: Dr Dave]
#2247096
02/04/17 11:27 AM
02/04/17 11:27 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
To me much depends on how much street and or race you plan to use it. And as many said with that big Hemi you dont need as much gear as it should have the torque to pull about the same et with lower number gears. Of course if you plan to race it and put sticky tires on it then I would go with a Dana or Ford 9" with the manual trans. I also agree it will work better with a taller tire. I run a 30" tall tire on my 63 with a 440/493 wedge that I am sure makes alot les power then your Hemi and the 30" tires work nice for me at the track and on the street. If you plan to race alot I would go with about a 30" tire and run 3.91's with your combo. Good luck what ever you decide on. Ron
[Re: 383man]
#2247154
02/04/17 01:21 PM
02/04/17 01:21 PM
Posts: 12,017 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Just say no to a phord 9" in a Mopar. Danas are super cool and tough and if the OP is gonna beat on the thing hard with sticky tires, it is the ultimate rear. But his 8 3/4 will handle most duties. I have had an 8 3/4 in my Cuda with a 500" Wedge for more than a decade. And now have a 540 Hemi in front of it. I have hurt a couple of gear sets over the years but that still doesn't amount to the cost of a Dana. We run 3.91s. Mostly because they are a good compromise between fun and hiway cruising. If we ran more hiway, we would have higher gears. If we raced more, we would have lower gears. But 3.91s are a good match for the way we run our cars.
Master, again and still
[Re: Dr Dave]
#2247382
02/04/17 09:33 PM
02/04/17 09:33 PM
Posts: 452 Monrovia, So-Cal, USA
racerhog
My 2 cents...... 3.91 gear ratio.... And the next time you buy tires go with a 28" or 29"... That should put that 528" motor in the sweet spot...
Bob(Cowboy)Hogan Monrovia So-Cal
