Trunk Light Activation Switch 1970 B-Body
#2243346
01/29/17 01:43 PM
01/29/17 01:43 PM
Posts: 265 Philadelphia, PA
GTXKARL
Philadelphia, PA
Can the trunk light activation switch be taken a part fto be repaired? I think the spring broke on mine. Thank you. -GTXKARL
“Working on cars teaches you patience... and every curse word imaginable.”
1970 Plymouth GTX -- A true gentleman's coupe, but a serious muscle machine.
Re: Trunk Light Activation Switch 1970 B-Body
[Re: GTXKARL]
#2243509
01/29/17 06:34 PM
01/29/17 06:34 PM
Posts: 5,435 So Cal
Sinitro
So Cal
I recall the trunk lite switch can be repaired if all the pieces are there, usually they just need to be kleened out removing any rust or oxidation. Note its the same as the parking brake switch except the electrical terminal is bent @ a 90 degree angle. Just my $0.02...
[Re: L.R Helbling]
#2243911
01/30/17 01:07 PM
01/30/17 01:07 PM
Posts: 6,221 JERSEY
RJS
JERSEY
If the '70 switch is anything like the '71 which I suppose it is, it is activated by a mercury float switch imbedded into the socket body of the switch assembly. This is not serviceable. The top of socket may just need cleaning and lubrication. Try a round brass bristle brush and some penetrating lube to get the spring to rebound. If the spring is broken, you maybe looking at a new trunk light switch. They are affordable on eBay.com and are not impossible to find with an unmolested wire harness. 70 and 71 two different types Ron
[Re: L.R Helbling]
#2243949
01/30/17 02:20 PM
01/30/17 02:20 PM
Posts: 2,914 Calgary, Alberta Canada
a12rag
Is it this that you are looking to re-refurbish:
http://www.ebay.com/itm/MOPAR-68-69-70-B-BODY-TRUNK-LIGHT-SET-CORONET-CHARGER-BEE-ROAD-GTX-SATELLITE-/112242212319?hash=item1a22283ddf:g:ZIAAAOSwEzxYWEQG&vxp=mtr This one is correct for 1970. That is what I have in my 70 Sport Satellite....spring loaded. The other style is mercury switch, from newer year . . .
