Are Alcohol Heads different Than Fuel #224292
02/14/09 10:33 AM
02/14/09 10:33 AM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
Just have a quick question are alcohol heads different design than gas/fuel heads on a hemi, or are they the same between the two fuels? If they are different what are the changes? Also what are the differences in piston design? Would an alcohol head work on a fuel motor with correct pistons? Thanks
Re: Are Alcohol Heads different Than Fuel [Re: maximus] #224293
02/14/09 12:15 PM
02/14/09 12:15 PM
Sao Paulo, Brazil
dart_73_br Offline
dart_73_br  Offline
Sao Paulo, Brazil
The main difference is that you need more CR to run Alcohol, so a minor chamber. I think > 10.5:1 CR should be fine!
Sorry... I tought in ethanol.... here in Brazil is full of Alcohol cars... or ethanol....
Re: Are Alcohol Heads different Than Fuel [Re: maximus] #224294
02/14/09 01:27 PM
02/14/09 01:27 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
They can be swapped, but there are a few differences.
Most Alcohol heads use special head studs that allow the removal of the rocker gear without affecting head torque. It's a special stud with two nuts. The head must be cast and machined for this.
Fuel heads also run rocker arms with no roller tips (at least on the exhaust). The valve sizes are a little different too because it has more effect with an alcohol motor. The CR is different, but that's up to the piston not the head.
Re: Are Alcohol Heads different Than Fuel [Re: maximus] #224295
02/14/09 01:52 PM
02/14/09 01:52 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
There are many differences between fuel and alcohol heads, so NO they are not even close to being the same. Fuel heads has down nozzles that alcohol heads doesn't have for one.
web page
Re: Are Alcohol Heads different Than Fuel [Re: Challenger 1] #224296
02/14/09 02:54 PM
02/14/09 02:54 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Good point - I totally overlooked that. Here's a pic of a Top Fuel head showing the nozzles.
Post deleted by Defbob [Re: Mopar_Rich] #224297
02/14/09 07:30 PM
02/14/09 07:30 PM
Re: Are Alcohol Heads different Than Fuel #224298
02/14/09 08:09 PM
02/14/09 08:09 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
But for the most part they are the same in basic design
I would bet that an Alcohol Motor would run on Nitro with just cam, injector, and compression changes...like thats no big deal...
Re: Are Alcohol Heads different Than Fuel #224299
02/14/09 09:27 PM
02/14/09 09:27 PM
Cincinnati, Ohio
Cincinnati, Ohio
if we talk billet heads
What else is there in alcohol/nitro racing?
Re: Are Alcohol Heads different Than Fuel [Re: maximus] #224300
02/14/09 09:46 PM
02/14/09 09:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you saying fuel as in gasoline OR fuel as in a
top fueler... because the only differences in my alky
head vs a gas head was the valve dia, being the alky
head gets a larger valve dia..... this is on a W-9
Post deleted by Defbob [Re: Challenger 1] #224301
02/14/09 10:20 PM
02/14/09 10:20 PM
Re: Are Alcohol Heads different Than Fuel #224302
02/14/09 10:30 PM
02/14/09 10:30 PM
MI, Lapeer
maximus Offline OP
maximus  Offline OP
MI, Lapeer
I am talking alky and gasoline. Sorry about the confusion. Would alcohol heads work on a street/strip motor? These are DART hemi heads I am taking about. Thanks
Re: Are Alcohol Heads different Than Fuel [Re: maximus] #224303
02/15/09 06:37 AM
02/15/09 06:37 AM
I have seen this kind of post on other sites and I think one thing that no one ever asks is what kind of preformance are you looking to get? If you mean will the motor run then yes. Will it get more hp and or tq from one to the other then that is where the debate is. There are a ton of differences in the hemi head world.The older heads stay alot closer to the standard 426 heas but the later model stuff is way different.Just my 2 cents
Re: Are Alcohol Heads different Than Fuel #224304
02/15/09 07:10 AM
02/15/09 07:10 AM
Maple Ridge, BC, Canada
N
NitroFixx Offline
NitroFixx  Offline
N
Alan Johnson Billet fueler heads with nozzles, lines and rails.
Re: Are Alcohol Heads different Than Fuel [Re: Mopar_Rich] #224305
02/15/09 07:13 AM
02/15/09 07:13 AM
N
NitroFixx Offline
NitroFixx  Offline
N
combustion chamber of Alan Johnson Fueler head
