Re: Bad battery cause of a rough idle?
[Re: Belvedere1]
#2308315
05/21/17 02:25 AM
05/21/17 02:25 AM
Posts: 10,198 Someplace you aren't
SomeCarGuy
I haven't read this all but will throw out there you may need to drill small holes in the primaries to get it down on the idle circuit. I wouldn't be surprised at 1100 if you were on the main circuit.
I want my fair share
[Re: Belvedere1]
#2308352
05/21/17 07:58 AM
05/21/17 07:58 AM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Perhaps I have missed it, where is our initial ignition timing? Are throttle butterflies at idle so far open to cause you carb to be running in transition circuit instead of idle circuit. A simple test is to adjust idle mixture screws,,,,does this cause significant difference in idle speed? Crank initial timing up to say 15 to 20 degrees which will likely increase idle speed, then adjust speed back to normal using carb idle speed adjuster, with screw idle mixture screws out from all the way in, out say to 1.5 turns...Any improvement?
Have you tried earlier recommendation to bypass ignition wiring by jumping directly to coil from battery.
Your idle vacuum reading is extremely low unless some crazy camshaft. ,,are you certain of no major vacuum leaks,,,,power brake booster,,,intake to head, cracks in intake manifold. I've even run a garden hose on low pressure on a running engine and been surprised by what I have found.
Any bad cylinders,,,pull plug wires one at a time with engine idling best it can with vacuum gauge connected. Any cylinders with zero change in vacuum reading?
Carb float levels ok?
[Re: Belvedere1]
#2308926
05/22/17 06:26 AM
05/22/17 06:26 AM
Posts: 20,622 in a cattle trailer down by th...
Guitar Jones
The first thing I would have done was throw that POS carb in the trash and put a good Holly on it. I like the ones with the down leg boosters instead of the straight leg boosters.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Belvedere1]
#2309123
05/22/17 03:13 PM
05/22/17 03:13 PM
Sxrxrnr
Northern Calyfornua
Meter voltage at plus side of coil when engine is cold, and again when warm. Should be at 12 volts unless you have a ballast resistor,,,about 9 volts then. Does it change between hot and cold, if not I would not suspect battery. Might suspect ballast if you have one,,,or other ignition components, wiring, connectors etc.,,,,hence recommendation to jump from battery plus to coil plus just to eliminate any possibility here. A defective coil could be at fault if begins to fail due to internal heat or as engine warms.
I might measure again when in park and when in drive. Change? If voltage decreases when in gear,,,could be battery if slowed down idle decreases a marginal alternator's output sufficiently.
Can we assume that non idle performance is as you expect,earlier post is a bit murky on this point. If so, I would lean more to a carb problem. Again ask where are butterflies in relation to transition circuit? 2 1/2 turns out on carb idle mixture screws sound excessive,,,what happens when screwed further in,,,,really close in or closed engine should die. If not,,,I am very curious as to butterfly position,,indicating if engine not running on idle circuit of carb at idle but on cruise circuit.
When running engine from fresh cold start and idling at what you assert of is about 1,200 rpm, I assume that you are not running on fast idle cam of carb. If not can you manually force carb butterflies toward closing. Spray a little wd 40 at carb and cable linkage to ensure no friction that may disappear as engine warms. I would likely disconnect accelerator linkage to eliminate this from equation.
[Re: Belvedere1]
#2309720
05/23/17 12:39 PM
05/23/17 12:39 PM
RapidRobert
I do have an old AFB I could throw on there I would
