Re: How much is too much hard block
[Re: mopar dave]
#2238701
01/21/17 10:54 PM
01/21/17 10:54 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
We fill to the bottom of the core plugs
1963 Plymouth Max Wedge 1971 Barracuda
[Re: mopar dave]
#2238703
01/21/17 10:57 PM
01/21/17 10:57 PM
ozymaxwedge
Australia
But yes keeping it cool is a trick, I have a 528 on the street in a 71 Barracuda, it has a new large ali radiator with twin fans and I fitted a engine oil cooler but on a hot day on the highway it gets too hot.
[Re: mopar dave]
#2238731
01/21/17 11:34 PM
01/21/17 11:34 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
We have a high fill on the 440 block in the Barnyard Viper. Filled to the bottom of the water pump holes. We run an oil cooler, but still kills the oil on occasion. The water temp never gets over 200.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: mopar dave]
#2238784
01/22/17 12:52 AM
01/22/17 12:52 AM
Posts: 19,357 Las Vegas
Al_Alguire
Las Vegas
Water temp will not be an issue..Oil temp will. Less water to cool so those temps will or should not get really high. Oil temps will be the issue
[Re: mopar dave]
#2238800
01/22/17 01:11 AM
01/22/17 01:11 AM
Posts: 4,457 Washington
madscientist
Washington
You need an 8 quart oil pan and a QUALITY oil.
That means an oil you probably can walk into a store and buy.
Not a fan of engine oil coolers.
[Re: mopar dave]
#2238825
01/22/17 02:05 AM
01/22/17 02:05 AM
Posts: 8,163 Plymouth, MI
Blusmbl
Plymouth, MI
Oil coolers are fine if the pump, and lines to the cooler, are sized appropriately. Lots of OEM applications have them, especially the heavier duty engines. Combustion heat has to go places, and with a filled block it heads to the oil.
[Re: mopar dave]
#2238833
01/22/17 02:29 AM
01/22/17 02:29 AM
MoparBilly
Phoenix, AZ
The thing with the truck was, an old race engine got converted to street duty. Boone would complain about killing the oil on Drag Week, saying that when it ran over 240 oil temp for a period of time, it would start to burn it, and then oil pressure would drop fifteen to twenty lbs.
He always ran Valvoline VR-1 50wt. in it.
When I got the truck down here in Phoenix, I added a plate cooler that was 2 inches longer than the previous one, and switched to Lucas Classic 20-50wt.
Even though I have seen oil temps in the 240-250 range, I've never experienced pressure drop (solid 65lbs.) or burning, so I'm going to chalk it up to better oil choice.
It's not ideal, but sometimes you just use what you have.
[Re: ccdave]
#2238855
01/22/17 03:09 AM
01/22/17 03:09 AM
MoparBilly
Phoenix, AZ
I would find a different block and start over. Yeah, But I like driving them more than I like working on them, and as long as the old girl still slams me back in the seat, I'll keep beating on it! It's a 440 source flat-top 4.25 stroke kit. topped with the old Edelbrock RPM heads/Isky ductile rockers that I've used since '99. Not once piece on that engine owes us a darn thing!
[Re: mopar dave]
#2238986
01/22/17 01:55 PM
01/22/17 01:55 PM
Posts: 7,506 Az
Crizila
Az
As said, water temp won't be the problem. Oil temp will. Personally, I wouldn't do it on a street application. If you decide to do it, I wouldn't go over a half fill - and count on using an oil cooler. On the plus side, todays lubes ( especially synthetics ) can handle ( and are designed to run at ) much higher temps than in the past. Running oil temps in the 250 range are not uncommon.
Fastest 300
[Re: Crizila]
#2239019
01/22/17 02:54 PM
01/22/17 02:54 PM
Posts: 20,153 PA.
pittsburghracer
"Little"John
"Little"John
PA.
As said, water temp won't be the problem. Oil temp will. Personally, I wouldn't do it on a street application. If you decide to do it, I wouldn't go over a half fill - and count on using an oil cooler. On the plus side, todays lubes ( especially synthetics ) can handle ( and are designed to run at ) much higher temps than in the past. Running oil temps in the 250 range are not uncommon. Its already done. No turning back on that block now.
