440 stamped rocker arm replacements
#2237866
01/20/17 01:57 PM
01/20/17 01:57 PM
Posts: 51 Duluth, Minnesota
Moondog
Duluth, Minnesota
I am restoring a 1970 440 magnum, and am wondering which rocker arms to purchase. I have used the Mopar Performance rocker arms for decades, but have been only able to purchase the RIGHT(P4529476) side. The LEFT(P4529477) are nowhere to be found. I am placing an ad in the WANTED section, also. There are other brands made by Elgin, and Sealed Power, and am wondering if anyone has had good luck with aftermarket. How do they compare in ratio and side clearance? Thanks
Founder of, and reason for, the RED LIGHT RACE TEAM
Re: 440 stamped rocker arm replacements
[Re: Moondog]
#2237878
01/20/17 02:07 PM
01/20/17 02:07 PM
crabman173
crabman173
The ones available from elgin, Ebay etc that I have seen are not usable--they are much too narrow--they are thin. I had several in last batch that the stamped hole would not allow shaft to pass--I opened them up--ran them on test stand 440--there was a weird chatter and noise--replaced them all with good used units and it went away so for time being until good quality units come back--I am using recycled old stockers when need be.
[Re: ]
#2238096
01/20/17 08:48 PM
01/20/17 08:48 PM
Moondog
Duluth, Minnesota
Thanks for the input, that is what I thought. Other people have told me they are cleaning up their used stuff.
[Re: Moondog]
#2356726
08/19/17 07:29 PM
08/19/17 07:29 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Anyone running Sealed Power Replacements ? From Summit Racing
Thanx Scott
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
