question for ANDYF on indy crossram linkage
#223693
02/13/09 07:56 PM
02/13/09 07:56 PM
andy is the carb linkage you make for indy the same for the 426-8 indy crossram and the 440-25 indy crossram? or do y6ou make a different setup for the indy hemi setup? your throttle bracket and carb work great are they interchangeable? im thinking the indy crossram for the hemi might be the hot ticket over the MP crossram making much more power.
Re: question for ANDYF on indy crossram linkage
[Re: AndyF]
#223695
02/13/09 08:47 PM
02/13/09 08:47 PM
Andy, i think a great test for you would be a hemi build with the MP Creossram and the indy hemi crossram comparison, i know its costly but i think it could have some valueable information with dyno numbers,A/F ratios ,etc. you did the max wedge comparison and i think this would be a great learning experience. thanks for the reply.
