Page 1 of 3 1 2 3
511 combo victor head distributor issue #2235132
01/16/17 02:38 AM
01/16/17 02:38 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Had a few issues assembling the 511 yesterday. First, the stamped chain cover from 440sourse sucks. Looks like it was stamped wrong as the crank snout opening was to the left of center.Had to drill the pin locating holes in the pan much larger. Loosen all the bolts and I think it self centered as I installed the damper. Looked ok when I was done.Hope it don't leak. The timing indicator from 440 also was a joke. Not even close to TDC, off by 4* and best I could do adjusting was still 2* off. One other thing is the distributor hits the head and I can not install it without grinding some aluminum off the head. Would that be the cure or do I need a distributor that will fit with the victor heads? Thanks
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235170
01/16/17 06:25 AM
01/16/17 06:25 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
We had to grind the head to fit an MSD distributor. I can post pics if needed.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235174
01/16/17 08:08 AM
01/16/17 08:08 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I had to grind ALOT off my Eddy head to clear the Pertronix billet distributor.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235181
01/16/17 10:19 AM
01/16/17 10:19 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I will always send stuff back before I try to make it fit. These companies need to learn parts that don't fit are unacceptable and they need to tighten down on their manufacturer.
As far as the distributor, on my lowdeck with Victor heads, it's super close so I'm surprised they haven't made a casting change yet.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235197
01/16/17 11:38 AM
01/16/17 11:38 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Had to grind on my Stage VI's back in the day even with the MSD Pro Billet distributer.
Re: 511 combo victor head distributor issue [Re: J_BODY] #2235206
01/16/17 11:54 AM
01/16/17 11:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
There is a off set dist for those engines...
I forget who makes it.. it has a belt that
turn the second shaft(a shaft up from the
engine to a cogged belt to a second shaft
that is the dist)
wave
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235210
01/16/17 12:02 PM
01/16/17 12:02 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
How about indexing the dist over 1 wire?
Re: 511 combo victor head distributor issue [Re: Clanton] #2235212
01/16/17 12:07 PM
01/16/17 12:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
My understanding is the dist housing hits the head..
not the vac pot so indexing wouldnt change it.. most
of the guys clearance the head or go with the off set
dist
EDIT
Also Dave.. have your valve covers on also to
make sure they clear.. I heard some had to re-
work that corner of the covers... when I mocked
up my mega block with B1 m/c heads the dist was
hitting.. I didnt have V/Cs at that time but I
think they would have crashed.. thats why I was
looking at the off set dist
wave
Re: 511 combo victor head distributor issue [Re: ProSport] #2235219
01/16/17 12:29 PM
01/16/17 12:29 PM
Mt Morris Michigan
Mt Morris Michigan
yes, pertronix billet dist. is what I have also. it wont even come close to lining up with the oil pump shaft. I bought the dist litely used from a member here, so looks like I will have to grind the head to clearance.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235226
01/16/17 12:40 PM
01/16/17 12:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Once you get the dist in you may have to grind on the valve cover also,What valve covers do you have?I had to grind mine to clear the rocker in that corner.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235234
01/16/17 12:49 PM
01/16/17 12:49 PM
Central California
MoParFish Offline
MoParFish  Offline
Central California
Victor heads, MSD Pro Billet, close but doesn't touch. twocents wrench
Sworn Member Central Valley MoPar Drag Pack. You can reach me at (done-et-chasing@going-rounds.gone)... :-)
[img]https://s6.postimg.org/v3mbggksx/SAC16.jpg[/img]image hosting more than 5mb
Re: 511 combo victor head distributor issue [Re: Clanton] #2235239
01/16/17 12:56 PM
01/16/17 12:56 PM
Mt Morris Michigan
Mt Morris Michigan
I ordered some speedmaster covers in carbon fiber from Jegs about 5 wks ago. Don't have them yet. Maybe I should wait for the covers, if they need clearancing as well I might just look for a MSD dist.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235240
01/16/17 12:56 PM
01/16/17 12:56 PM
AndyF Offline
AndyF  Offline
Belt drive distributor clears just fine!
Re: 511 combo victor head distributor issue [Re: MoParFish] #2235241
01/16/17 12:57 PM
01/16/17 12:57 PM
Mt Morris Michigan
Mt Morris Michigan
Thanks, good to have options
Re: 511 combo victor head distributor issue [Re: MoParFish] #2235248
01/16/17 01:04 PM
01/16/17 01:04 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I have the same dist but like I said the inside of the v cover hit the rocker on the sealing lip I had to grind back but I still have to pull the dist cap to pull the v cover.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235257
01/16/17 01:12 PM
01/16/17 01:12 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
I have a stock distributor on mine with no issues, I also have a stock valve cover on one side and it fit with only some minor hammer whacks
Re: 511 combo victor head distributor issue [Re: Clanton] #2235262
01/16/17 01:17 PM
01/16/17 01:17 PM
Mt Morris Michigan
Mt Morris Michigan
ok, ill wait til the covers get here. May get a different dist.
Doesn't Firecore offer a dist. for this issue?
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235271
01/16/17 01:38 PM
01/16/17 01:38 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I think so but will not help the valve cover on/off.What rockers?My HS stick over the seal lip.
Re: 511 combo victor head distributor issue [Re: Clanton] #2235275
01/16/17 01:43 PM
01/16/17 01:43 PM
Mt Morris Michigan
Mt Morris Michigan
Yep, Harland sharp.
Re: 511 combo victor head distributor issue [Re: mopar dave] #2235276
01/16/17 01:44 PM
01/16/17 01:44 PM
CA
bbodee Offline
bbodee  Offline
CA
RB engine/ Victor heads- The msd pro billet clears the heads fine, but I needed to clearance the value cover rail as can be seen in the pics. I wish there was room to run a cap adapt with the larger cap but that's never going to happen!
Page 1 of 3 1 2 3
