What Octane Fuel for my 10.1 446
#223180
02/13/09 11:51 AM
02/13/09 11:51 AM
Posts: 4,282 Danville, NH
Mopar_Mike
Danville, NH
I have a 66 446 block with stock edelbrock heads and TRW 2255 six pack pistons. I am running 10.1 compression. For the street I will run 93 octane, but when I go to the strip will I benefit from the higher octane racing fuel? I think it is around 105-108 octane. Thanks.
RS23L7 4-Speed
Re: What Octane Fuel for my 10.1 446
[Re: Mopar_Mike]
#223182
02/13/09 12:01 PM
02/13/09 12:01 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Theres really no reason to up the octane unless you just plan on being safe. Also if you up the octane without adding some timing.... you would go slower. The cam makes a big difference in the cyl pressure... when it closes
[Re: Mopar_Mike]
#223183
02/13/09 12:13 PM
02/13/09 12:13 PM
Posts: 302 Casa Grande,Arizona
DennisJ
super street
super street
Casa Grande,Arizona
You should use the lowest octane that does not cause detonation. With Edelbrock heads you could use the middel grade at the pump.The aluminum head helps the detonation problem.
Dennis Jokela
I started out with nothing,and I still have most of it.
[Re: bobby66]
#223185
02/13/09 12:45 PM
02/13/09 12:45 PM
Posts: 1,328 St. Louis, MO
mopardamo
St. Louis, MO
I use the same pistons and heads on my 446. Hydraulic cam [Email]242@.050.[/Email] Need a couple gallons of 110 at the track or it will rattle.
Hello,
How old is the motor? Might have some oil contamination issues. I had the same problem when my last motor needed freshening.
Damon
