gettin spark for a second
#2230589
01/09/17 01:51 AM
01/09/17 01:51 AM
Posts: 459 las vegas,nv
mopar muscle7271
las vegas,nv
I have a 71 dart with a 440 factory electronic igination.when i turn the key on i get spark.i will lose spark when the engine is tryin to start.when i let go of the key i kinda have spark again. Possibly the ignition switch or coil?
Re: gettin spark for a second
[Re: mopar muscle7271]
#2230638
01/09/17 04:56 AM
01/09/17 04:56 AM
Posts: 43,097 Bend,OR USA
Cab_Burge
It sounds like one of two things, loose or dirty connection on the ballast resistor or a wiring problem from the ignition switch to the ballast resistor. Someone put that motor and ignition in that car, check all the connection closely first and then use a volt meter to check the voltage (check the voltage at the battery first, if it is around 12.6 volts) to both ends of the ballast resistor, you should have almost the same voltage,12.4 to 12.6 V, at the ballast on one end and around 6.0 to 8.5 volts to the other end with the key on and the engine not running Next thing is to put the shifter in some gear position other than neutral or park and have a helper turn the ignition switch to the start position while you check the end of the ballast resistor that had the lower voltage with the key on, it should increase to battery voltage or a tiny bit less in the start position to that end of the ballast resistor to make the coil fire when in the start position Mopar electrical engineers made it harder on us to trouble shoot problems in their design of theses cars Let us know what you find and have to do to fix it, that will help others on here later
#2230644
01/09/17 05:48 AM
01/09/17 05:48 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
check the air gap on the distributor also...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 70AARcuda]
#2230696
01/09/17 11:34 AM
01/09/17 11:34 AM
RapidRobert
5 pin/4 terminal "dual" ballast system or 4 pin/2 terminal "single" ballast system? As said: bad box/open in ballast/too much reluctor gap
#2230703
01/09/17 11:55 AM
01/09/17 11:55 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Since the ballast is bypassed in start and he's only getting spark in run I seriously doubt it's the ballast resistor.
Since you get a spark at all I doubt it is the coil.
Since the ignition switch is what bypasses the ballast I suspect that or the wiring/connectors.
[Re: buildanother]
#2230736
01/09/17 12:38 PM
01/09/17 12:38 PM
RapidRobert
I had that exact same symptom once & it was either the box or the ballast I can't remember which
#2230892
01/09/17 04:42 PM
01/09/17 04:42 PM
Posts: 5,080 organ
maximum entropy
organ
11 out of 10 times it's the ballast resistor...
#2230959
01/09/17 06:15 PM
01/09/17 06:15 PM
Posts: 2,094 central texas
krautrock
central texas
in that case definitely pay attention to ign1 and ign2. one is hot when ign is in start, the other hot while ign is in run. they both need to go to...the coil...or the ign box (in my case my msd) or wherever depending on yr ignition setup. look at a schematic.
#2231013
01/09/17 07:21 PM
01/09/17 07:21 PM
Posts: 953 Chicago
PurpleBeeper
Chicago
OK guys..... look at the original post. If I'm reading it correctly, then he has spark at "run", but no spark at "start" position of the key.
This is the OPPOSITE of the typical ballast resistor burning out. If I'm reading that correctly, then there's either a problem with the brown wire coming out of the bulkhead disconnect (the one that bypasses the ballast resistor) or the ignition switch itself.
One way to test this would be to run a jumper wire from the + of the battery to the disconnected ballast resistor plug that has the brown wire. If the car starts & stays running, then you've found the problem. Don't just leave that wire hooked up though since your ignition voltage is supposed to be "stepped down" with the ballast resistor during normal running & this jumper wire isn't going through the ballast resistor.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: Andrewh]
#2231050
01/09/17 08:07 PM
01/09/17 08:07 PM
Supercuda
About to go away
About to go away
up yours
sure. same thing to me. electronic part.
if the key movement is allowing something to happen in the box even though it isn't working, then you won't be able to start the car by bridging the start relay.
if it does start then you have an issue with the circuit that should power the coil/spark box when in start.
it should be pretty quick to see which. The ECU doesn't care if the key is in run or start, it is powered the same regardless. What is powered differently is the coil. So, if the ECU makes a spark at all it is working.
[Re: Andrewh]
#2231179
01/09/17 11:04 PM
01/09/17 11:04 PM
Supercuda
About to go away
About to go away
up yours
sure, but my statement is still good. if he can start it in run then there is a circuit issue. if he cannot, then maybe it isn't the ecu, but something died and has to be replaced. it narrows down this chase. True, but for any test to be useful you have to know what it is doing.
[Re: Supercuda]
#2231207
01/09/17 11:36 PM
01/09/17 11:36 PM
RapidRobert
I'm thinking it might be hard to decipher if it is on "run" or "crank" in that split second when the key is being released from crank to run when there is the one spark. What I would do is pull the yellow wire off of the "ign" terminal on the starter relay to disable the starter (we know it cranks & no need to run the batt down for this testing) and charging the battery up with the alt causes system problems and have a helper hold the key to "crank" & see if the coil positive primary terminal and the blue/yellow ECU terminal is hot (the red/green terminal on an OE 5 pin ECU needs to be hot also) then release the key to "run" & see if everything is still hot. grab your meter.
#2231246
01/10/17 12:14 AM
01/10/17 12:14 AM
RapidRobert
Progress! looking good. EDIT I'd get the new ECU in & see what happens. Standard Motor Products used to make a good American made parts house ECU but it is made in China now (iirc it is $25).
#2231879
01/10/17 10:12 PM
01/10/17 10:12 PM
RapidRobert
Lets do this, hook everything back up & hold the coil secondary wire (dist end) 1/4" away from the intake (ground) and with the dist pickup zigzag pull apart connector seperated, drag the male tip end of the body half across the intake surface (ground) & see if the coil wire sparks (do it with key on and with key held to start with the yellow wire terminal pulled off of the "ign" terminal on the starter relay). then reconnect the zigzag connector and remove any and all wires off of the dist neg primary post (might just be the one) and with a jumper wire connected to the coil terminal itself (not to the ring terminal you removed from it), tap tap the other alligator clip on the other end of the jumper to the intake & same thing see if the coil wire sparks (with key on & key held to crank). Holler back.
#2232053
01/11/17 01:29 AM
01/11/17 01:29 AM
Supercuda
About to go away
About to go away
up yours
If the coil sparks it's not the coil, though I did have a coil that would intermittently fail when it got hot, but it failed in either mode. It would work when cooled off. Took awhile to sort it out but I got it.
Eventually you will have to break out a meter and find out what is going on.
#2232082
01/11/17 02:37 AM
01/11/17 02:37 AM
mopar muscle7271
las vegas,nv
I have a meter and will test the coil and see what the reading says. It was hot when the last time i tried starting it.
[Re: OzHemi]
#2232094
01/11/17 02:56 AM
01/11/17 02:56 AM
RapidRobert
Neat tool, What is the gap when it gets to "super"? it would be a "cold" test. EDIT now I see the numbers for the gap
#2232103
01/11/17 03:43 AM
01/11/17 03:43 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Are you saying it sparks once when you turn the key off ? As it sounded like thats what you were saying at first ? No spark while cranking but a spark when the key is turned off ? I just want to be sure just what it is doing. Ron
#2232116
01/11/17 04:17 AM
01/11/17 04:17 AM
mopar muscle7271
las vegas,nv
I turn the key on i have spark.when i crank the key the over to start it,i loose all spark.when i let go of key i have alittle spark again.
[Re: Kern Dog]
#2232979
01/12/17 05:53 PM
01/12/17 05:53 PM
mopar muscle7271
las vegas,nv
Ok i replaced the distributor last year in it,maybe its bad again. I have replaced all those items.would fouled up spark plugs cause a no start as well?
[Re: OzHemi]
#2233039
01/12/17 07:24 PM
01/12/17 07:24 PM
RapidRobert
I don't use it often, but still a kind of cool thing to have around.
Instructions on it, if you were curious..
Yeah I see the heat setting on it.
#2233041
01/12/17 07:29 PM
01/12/17 07:29 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Ok i replaced the distributor last year in it,maybe its bad again. I have replaced all those items.would fouled up spark plugs cause a no start as well? I think fouled plugs may make it harder to start, misfiring at all speeds but not a "no-start" condition unless the electrodes are burned off or there are so many deposits in there that no gap remains between the tip and electrode.
#2233379
01/13/17 07:15 AM
01/13/17 07:15 AM
383man
Balt. Md
No spark when crankin engine over.only spark is when the key is on and not crankin the engine trying to start. Ok now you say only spark when key is on ? Now is that just one spark when key is turned on and or off or a continuos constant spark as I have seen a bad ECU actually cause a spark that just keeps sparking with the key on and the coil wire held 1/4" away from ground. Or if its just one spark when key is turned on then off then that tells you the coil and wiring is good. And if you jump the starter and crank the eng with the key on and get no spark then it may just be a bad pick-up coil. Because if you get at least one spark when key is turned on then off it tells you the coil will fire when the primary circuit is turned off as it should. That would tell me the ECU is just not getting a signal to turn the coil primary circuit off so the magnetic field will collapse and fire in the coil secondary circuit. This is why I asked the specifics about just what is going on ? Now if you crank the eng by jumping the starter with the key in the on posistion and get spark but get no spark when cranking the eng by the key then thats a different problem in the wiring or the ign switch ign 1 and or ign 2 circuits. Ron
#2233576
01/13/17 04:43 PM
01/13/17 04:43 PM
mopar muscle7271
las vegas,nv
That comment is he wrote is dumb.theres other responding on tryin to tell me whats wrong.he wants to write something stupid like that.
#2233616
01/13/17 05:44 PM
01/13/17 05:44 PM
Posts: 7,363 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
Here is how the ignition switch works on your Dart. When you turn the key to "start" the car, power is sent on the brown wire directly to the coil and bypasses the ballast. When the engine starts and you release the key, power drops off of the brown wire and the blue "run" wire powers up. If you don't have any spark while cranking,(start position)then you have a problem with the brown "start" wire. Disconnect the yellow wire at the starter relay so the starter doesn't crank while you test. Then, starting at the ignition switch connector at the base of the steering column, test the brown wire for power when the key is held in the "start" position. You should have power on both sides of the connector. If you have power there, then test both sides of the bulkhead connector. Keep testing the brown wire all the way to the coil. If you don't have power on the brown wire on the ignition switch side of the connector, you have a problem with the ignition switch. On my car, I had some loose connections in the ignition switch connector that I had to fix. I had power on one side of the connector but not the other.
[Re: burdar]
#2233643
01/13/17 06:36 PM
01/13/17 06:36 PM
RapidRobert
My apologies brother & I would (likely) be the first one to complain (& I have!) if it happened to me. I would suggest trying my prior tests with it good and hot (jumper on coil neg/drag pickup body half male tip). Gotta work fast as electronic devices cool off very fast (enough to change their functioning) when dealing with heat related issues and a person can always (if it will start), let it run again till it acts up then proceed with testing.
#2233777
01/13/17 10:39 PM
01/13/17 10:39 PM
RapidRobert
with make/break grounding of the coil neg if it (coil wire) sparks in run and crank that tells you the wiring is good to that point and that the coil is OK (at least cold). then with that hooked back up. dragging the male tip of the body half of the pickup zigzag connector across the intake, if the coil wire sparks in run and crank that tells you the wiring further downstream is OK & the ECU is OK (at least cold). All that is left is the pickup (ohm it, hot and cold) and backing up a bit, the ballast can act up when heated & cause an issue in the "run" tests.
#2233874
01/14/17 01:44 AM
01/14/17 01:44 AM
383man
Balt. Md
I turn the key on i have spark.when i crank the key the over to start it,i loose all spark.when i let go of key i have alittle spark again. Not trying to be smart here but this makes no sense. You say................ turn the key on I have spark , when I crank the key over to start it I loose all spark , when I let go of key I have a little spark again. OK you say when I turn key on I have spark ?? Well with the key on and not cranking the eng it wont spark so what are you saying ?? I asked do you mean when the key is turned to run you see one spark or a continuos spark ?? So just what does it do when you turn the key to run ?? You say when I crank the key to start I loose all spark so that tells us no spark while cranking. So turn the key to run and jump the starter and crank the eng and tell us just what it does then ? If still no spark then unplug the dist pick-up and drag the male wire harness connector to ground with the key in run and see if it sparks ? If it sparks like that but no other time then heck you may just have a bad dist pick-up. Have you tested the dist pick-up. Just be sure its good before you start testing the rest of the ign circuits. If you get no spark cranking the eng then crank the eng by jumping the starter with the key in the run position and let us know if it has spark ? Ron
#2233961
01/14/17 12:28 PM
01/14/17 12:28 PM
RapidRobert
correct no spark comin out of the coil wire when crankin the engine over to start. yellow wire pulled off of the starter relay to disable the starter. A helper holding the key to "crank". You under the hood dragging the male tip of the body half of the pickup connector across the intake while holding the secondary coil wire 1/4" from ground. if it sparks the pickup is open or its 2 wire connector is open or the gap is way too far open. then with a jumper wire with alligator clips do the coil test same way (key held to start/starter disabled/coil wire 1/4" away from ground) and tap tap tap the alligator clip to ground. I would clean the ECU bottom side just to confirm a good ground but at this point in time I am leaning toward the ECU but yes I would do the tests.
#2234495
01/15/17 04:45 AM
01/15/17 04:45 AM
70AARcuda
las vegas
Ever check the air gap on the pickup coil in the distributor?
Tony
#2256929
02/21/17 12:38 AM
02/21/17 12:38 AM
RapidRobert
it shouold be producing spark the whole time while im crankin the engine over to run. Correct EDIT whats left is the pickup and an intermittent connection somewhere. I would make up some jumpers with alligator clips/proper as needed connectors & sub em in one circuit at a time to pin it down. keep the battery charged & even better would to elim the pickup then use a spare dist (even a /6 one) to do the triggering to save the starter/keep from running the battery down. I'm assuming the ECU has a good ground since you changed it out & on the wiring only the ECU and the coil need to be fed in ign2 and the 2 wire connector between the pickup and ECU needs continuity as does the 2 wires connecting the coil/ECU for it to fire as long as all of those are correct.
#2256994
02/21/17 02:46 AM
02/21/17 02:46 AM
RapidRobert
soon as i let go of key i have spark again. you mean it kicks out 1 spark when you let off the key (to ign1 run).
[Re: Jjs72D]
#2257145
02/21/17 01:40 PM
02/21/17 01:40 PM
RapidRobert
what I would do is with some made up jumper wires with alligator clips/specific terminals as needed I would jump from a 12V source like the batt stud on the starter relay to/thru the ballast to the coil/ECU (duplicate ALL of the ign1/ign2 circuits) & pull the ign2 wire when (if) it starts. this takes the wiring completely out of the picture & only leaves the hard components which most you have replaced then if we are good so far we can start to remove one jumper at a time & restart it to pin down which circuit has the open or intermittent connection.
#2264796
03/07/17 12:09 PM
03/07/17 12:09 PM
RapidRobert
With (3) jumpers jump from the "batt" stud on the starter relay to: (1) blue/yellow terminal on the ECU pentastar connector (stick a thin/sharp pin into it) and (2) to the upstream (blue wire) end of the ballast and (3) and to the coil positive primary terminal. start it with the key & when (if) it starts then remove jumper #3. I'm assuming this is a 4 pin ECU??
#2265415
03/08/17 04:11 AM
03/08/17 04:11 AM
mopar muscle7271
las vegas,nv
How come i have very weak spark on the positive side of coil? when i run a hotwire from the positive side to battery to positive of coil i have good spark goin to it.what could be bad causin very little spark to not producing continuous spark with out hotwire?
#2265890
03/08/17 11:20 PM
03/08/17 11:20 PM
RapidRobert
You have a poor connection between the ign2 (crank) terminal on the ign switch and the coil (& maybe the ign1 "run" circuit also which is why when you bypass it with your jumper it starts. start with the bulkhead (a frequent culprit). Might be low voltage AT the ign switch (it has a connector which can be problematic but nothing like the bulkhead). A small metal bristle brush is good for the male ones and a spare male terminal for the female ones (the ones on both halves of the bulkhead). spray clean em when done. NAPA male ones are 725145 if you dont have any spare wiring/terminals laying around-99 cents ea.
#2266128
03/09/17 12:07 PM
03/09/17 12:07 PM
RapidRobert
Your sayin bulk head for the engine harness section? yes the bulkhead on the firewall that has the blue ign1 run and ign2 crank circuits.
#2266441
03/09/17 10:08 PM
03/09/17 10:08 PM
RapidRobert
grab or make 3 jumpers & get it running (pull the one when it starts) then we can work to pin down which circuit has a bad connection & then pin down (further) where in that (particular) circuit the bad connection is.
#2266471
03/09/17 10:53 PM
03/09/17 10:53 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
You could pull the dist, and spin it by hand to see if you get a spark in both the start and run key positions, just disconnect the neutral safety wire from the start relay, or put trans in gear other than park or neutral so the starter does not spin when in the start key position. If you get spark spinning the dist by hand in both positions, the problem is not the ignition or the wiring to it, but a problem with voltage drop when the starter load is applied.
If you don't get a spark spinning the dist by hand, then there is a problem in the wiring, dist pickup, or with the ECU.
[Re: 451Mopar]
#2266474
03/09/17 10:55 PM
03/09/17 10:55 PM
RapidRobert
^Excellent info^ EDIT & if you have another dist handy (even a /6), plug it in first & spin it for an easier start to this path.
#2268831
03/13/17 08:00 PM
03/13/17 08:00 PM
RapidRobert
Which wire was burnt? You might get it going with a stock dist/ECU/ballast then see if you want to upgrade. The ignitor I II and III are modules that bolt in the dist & elim the pickup/ECU/ballast. I have the I and the III (uninstalled as of yet). The I was 2 bucks at a swap meet for a Toyota & I can redrill the plate if I can get the V8 black ring with the green tape. the III I splurged on for the stock car (& my racing partner is paying for it) so I took a chance cuz it ain't my money in the hat.
#2269041
03/14/17 12:17 AM
03/14/17 12:17 AM
RapidRobert
I'm thinking it would give a better mileage (probably not the highest on your list) and it would keep the plugs cleaner but if the demon doesn't have a ported nipple then its a moot point. EDIT might run a bit cooler (but you want no cooler than 180)
