Page 4 of 5 1 2 3 4 5
Re: gettin spark for a second [Re: Jjs72D] #2257145
02/21/17 01:40 PM
02/21/17 01:40 PM
what I would do is with some made up jumper wires with alligator clips/specific terminals as needed I would jump from a 12V source like the batt stud on the starter relay to/thru the ballast to the coil/ECU (duplicate ALL of the ign1/ign2 circuits) & pull the ign2 wire when (if) it starts. this takes the wiring completely out of the picture & only leaves the hard components which most you have replaced then if we are good so far we can start to remove one jumper at a time & restart it to pin down which circuit has the open or intermittent connection.
Re: gettin spark for a second [Re: timeklr] #2257177
02/21/17 02:48 PM
02/21/17 02:48 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
Its a single its been replaced.
Re: gettin spark for a second [Re: mopar muscle7271] #2264666
03/07/17 12:57 AM
03/07/17 12:57 AM
las vegas,nv
las vegas,nv
i did some testing with a tester,i have more spark goin to negative side of coil then positive side.which i have a very little spark on that side of coil on postive,without hotwire. when i run a hotwire from the battery post on the postive side to positive of coil i have all spark on that side and none on negative. should i have spark just on the positive side and none at negative? should have i the equal aumount on both sides? what could this problem be?
Re: gettin spark for a second [Re: mopar muscle7271] #2264796
03/07/17 12:09 PM
03/07/17 12:09 PM
With (3) jumpers jump from the "batt" stud on the starter relay to: (1) blue/yellow terminal on the ECU pentastar connector (stick a thin/sharp pin into it) and (2) to the upstream (blue wire) end of the ballast and (3) and to the coil positive primary terminal. start it with the key & when (if) it starts then remove jumper #3. I'm assuming this is a 4 pin ECU??
Re: gettin spark for a second [Re: RapidRobert] #2264905
03/07/17 02:39 PM
03/07/17 02:39 PM
las vegas,nv
las vegas,nv
Yah it is.
Re: gettin spark for a second [Re: mopar muscle7271] #2265415
03/08/17 04:11 AM
03/08/17 04:11 AM
las vegas,nv
las vegas,nv
How come i have very weak spark on the positive side of coil? when i run a hotwire from the positive side to battery to positive of coil i have good spark goin to it.what could be bad causin very little spark to not producing continuous spark with out hotwire?
Re: gettin spark for a second [Re: mopar muscle7271] #2265612
03/08/17 03:14 PM
03/08/17 03:14 PM
las vegas,nv
las vegas,nv
Anyone on here have a similiar problem?
Re: gettin spark for a second [Re: mopar muscle7271] #2265890
03/08/17 11:20 PM
03/08/17 11:20 PM
You have a poor connection between the ign2 (crank) terminal on the ign switch and the coil (& maybe the ign1 "run" circuit also which is why when you bypass it with your jumper it starts. start with the bulkhead (a frequent culprit). Might be low voltage AT the ign switch (it has a connector which can be problematic but nothing like the bulkhead). A small metal bristle brush is good for the male ones and a spare male terminal for the female ones (the ones on both halves of the bulkhead). spray clean em when done. NAPA male ones are 725145 if you dont have any spare wiring/terminals laying around-99 cents ea.
Re: gettin spark for a second [Re: mopar muscle7271] #2265911
03/08/17 11:53 PM
03/08/17 11:53 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Sounds like typical bad grounds.
Check battery ground to engine block and body.
Reason is, a small amount of resistance here (cable and connections) will create a large voltage drop from the block to negative battery terminal when the high current of cranking the engine goes through the cable.
Also, ground the ECU to the engine block.
With the bad grounds, the ECU will not sense the trigger voltage from the distributor.
Re: gettin spark for a second [Re: RapidRobert] #2266118
03/09/17 11:53 AM
03/09/17 11:53 AM
las vegas,nv
las vegas,nv
Your sayin bulk head for the engine harness section?
Re: gettin spark for a second [Re: 451Mopar] #2266123
03/09/17 11:58 AM
03/09/17 11:58 AM
las vegas,nv
las vegas,nv
Ok i do have ecm mounted to block.i have a wire goin from the inne fender where the ecm is goin to the end of engine on head.where else to check for grounds?
Re: gettin spark for a second [Re: mopar muscle7271] #2266128
03/09/17 12:07 PM
03/09/17 12:07 PM
yes the bulkhead on the firewall that has the blue ign1 run and ign2 crank circuits.
Re: gettin spark for a second [Re: RapidRobert] #2266342
03/09/17 06:57 PM
03/09/17 06:57 PM
las vegas,nv
las vegas,nv
Ok i replaced that harness it had new terminals on it.i can go back and if there is any corrosion on them etc.i have to agree that there is a poor connection and something isnt sending enough spark like you said in the previous post.
Re: gettin spark for a second [Re: mopar muscle7271] #2266441
03/09/17 10:08 PM
03/09/17 10:08 PM
grab or make 3 jumpers & get it running (pull the one when it starts) then we can work to pin down which circuit has a bad connection & then pin down (further) where in that (particular) circuit the bad connection is.
Re: gettin spark for a second [Re: mopar muscle7271] #2266471
03/09/17 10:53 PM
03/09/17 10:53 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You could pull the dist, and spin it by hand to see if you get a spark in both the start and run key positions, just disconnect the neutral safety wire from the start relay, or put trans in gear other than park or neutral so the starter does not spin when in the start key position.
If you get spark spinning the dist by hand in both positions, the problem is not the ignition or the wiring to it, but a problem with voltage drop when the starter load is applied.
If you don't get a spark spinning the dist by hand, then there is a problem in the wiring, dist pickup, or with the ECU.
Re: gettin spark for a second [Re: 451Mopar] #2266474
03/09/17 10:55 PM
03/09/17 10:55 PM
^Excellent info^ EDIT & if you have another dist handy (even a /6), plug it in first & spin it for an easier start to this path.
Re: gettin spark for a second [Re: RapidRobert] #2266498
03/09/17 11:40 PM
03/09/17 11:40 PM
PA
maxwedge1 Offline
maxwedge1  Offline
PA
i havent read all the posts but have you replaced the pickup coil?
i have had the spark at only key on and off syndrome and a new pickup coil cured it in a mopar and a ford.
Re: gettin spark for a second [Re: maxwedge1] #2267069
03/10/17 10:20 PM
03/10/17 10:20 PM
las vegas,nv
las vegas,nv
I can try to replace the distributor again,i replaced it ounce.
Re: gettin spark for a second [Re: mopar muscle7271] #2267728
03/11/17 11:15 PM
03/11/17 11:15 PM
las vegas,nv
las vegas,nv
What should the ohms be on the mangetic pick-up coil on the distributor?i did some testing with a ohms meter.
Re: gettin spark for a second [Re: mopar muscle7271] #2268811
03/13/17 07:35 PM
03/13/17 07:35 PM
las vegas,nv
las vegas,nv
I found a burnt wire on distributor,took it back to autozone.goin with high performance distributor.probably will also bypass the factory electronic igination system.possibly with a msd box. the petronix igunitor type 2 or 3 good distributors?
