Re: gettin spark for a second
[Re: mopar muscle7271]
#2231246
01/10/17 12:14 AM
01/10/17 12:14 AM
RapidRobert
Progress! looking good. EDIT I'd get the new ECU in & see what happens. Standard Motor Products used to make a good American made parts house ECU but it is made in China now (iirc it is $25).
#2232053
01/11/17 01:29 AM
01/11/17 01:29 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If the coil sparks it's not the coil, though I did have a coil that would intermittently fail when it got hot, but it failed in either mode. It would work when cooled off. Took awhile to sort it out but I got it.
Eventually you will have to break out a meter and find out what is going on.
#2232082
01/11/17 02:37 AM
01/11/17 02:37 AM
Posts: 459 las vegas,nv
mopar muscle7271
las vegas,nv
I have a meter and will test the coil and see what the reading says. It was hot when the last time i tried starting it.
[Re: OzHemi]
#2232094
01/11/17 02:56 AM
01/11/17 02:56 AM
RapidRobert
Neat tool, What is the gap when it gets to "super"? it would be a "cold" test. EDIT now I see the numbers for the gap
#2232103
01/11/17 03:43 AM
01/11/17 03:43 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Are you saying it sparks once when you turn the key off ? As it sounded like thats what you were saying at first ? No spark while cranking but a spark when the key is turned off ? I just want to be sure just what it is doing. Ron
#2232116
01/11/17 04:17 AM
01/11/17 04:17 AM
mopar muscle7271
las vegas,nv
I turn the key on i have spark.when i crank the key the over to start it,i loose all spark.when i let go of key i have alittle spark again.
[Re: Kern Dog]
#2232979
01/12/17 05:53 PM
01/12/17 05:53 PM
mopar muscle7271
las vegas,nv
Ok i replaced the distributor last year in it,maybe its bad again. I have replaced all those items.would fouled up spark plugs cause a no start as well?
[Re: OzHemi]
#2233039
01/12/17 07:24 PM
01/12/17 07:24 PM
RapidRobert
I don't use it often, but still a kind of cool thing to have around.
Instructions on it, if you were curious..
Yeah I see the heat setting on it.
#2233041
01/12/17 07:29 PM
01/12/17 07:29 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Ok i replaced the distributor last year in it,maybe its bad again. I have replaced all those items.would fouled up spark plugs cause a no start as well? I think fouled plugs may make it harder to start, misfiring at all speeds but not a "no-start" condition unless the electrodes are burned off or there are so many deposits in there that no gap remains between the tip and electrode.
