Page 8 of 9 1 2 3 4 5 6 7 8 9
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #1999400
01/26/16 11:17 PM
01/26/16 11:17 PM
Texas
Donehundred Offline
Donehundred  Offline
Texas
Will the van LCA's work on a d200?
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: justin412] #2131695
08/13/16 01:15 AM
08/13/16 01:15 AM
Colorado, USA
Budd Offline
Budd  Offline
Colorado, USA
I'm a newbie here and I realize this is an old thread, but part, if not all your tie rod clearance problems are because the center-link needs to be swapped end for end.
Also check the taper in the steering arms to be sure you don't need to turn the rod ends over and insert from the bottom instead of the top.
If they are installed wrong it can result in sloppy steering, possible bumpsteer and even rod end failure.
BTW, I'm a retired forklift, automotive and small engine mechanic.
Not to mention an active MOPAR nut.
Budd
Budd Cochran
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Budd] #2228888
01/06/17 09:11 PM
01/06/17 09:11 PM
East Tennessee
Burkenator Offline
Burkenator  Offline
East Tennessee
Reviving this thread some. Does anyone know the length, bolt head size and nut size of the LCA pivot bolt? Was planning to order the LCA's from Rock Auto and getting some Grade 8 bolts and fasteners off the internet for the pivot bolts.
Great thread and thanks for the help!
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2230121
01/08/17 04:35 PM
01/08/17 04:35 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I havent did my swap yet, but I scored the lower control arms from a van with the bolts. I can tell you the bolts are grade 8 , 3/4 16 X 5" long
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2230124
01/08/17 04:37 PM
01/08/17 04:37 PM
Mrytle Beach SC
Mrytle Beach SC
Did anyone figure out the solution with the tie rods being mounted on the bottom so the tie rod angle is not so sharp.?
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2230129
01/08/17 04:41 PM
01/08/17 04:41 PM
Mrytle Beach SC
Mrytle Beach SC
For the guys that did the Dakota drop spindles, Did you use the parts off the Dakota , bearings, rotors, calipers, caliper brackets ect. I scored some billtech 2600 first gen dakota drop spindles and wonder if I need to go to the junkyard for those parts
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: johnscudashop] #2259716
02/26/17 12:09 PM
02/26/17 12:09 PM
East Tennessee
Burkenator Offline
Burkenator  Offline
East Tennessee
John--
Thanks for the help and info!!
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2260054
02/26/17 08:23 PM
02/26/17 08:23 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I used original inner tierods custom sleeves and heim joints for the outer.
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: moparborn] #2260220
02/27/17 12:38 AM
02/27/17 12:38 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Did that fix the bump steer? Did you have any bump steer?
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2260331
02/27/17 09:33 AM
02/27/17 09:33 AM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I did it all at the same time,drop spindles and heim joints,so I did not have any bumpsteer.
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2260890
02/28/17 03:29 AM
02/28/17 03:29 AM
Marysville, WA
77ProStreet Offline
77ProStreet  Offline
Marysville, WA
Thanks moparborn! Do you have any pictures?
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2261086
02/28/17 03:36 PM
02/28/17 03:36 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I will get some when I get to the garage(its winter,work on it home).
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: moparborn] #2329325
06/30/17 09:23 PM
06/30/17 09:23 PM
Mrytle Beach SC
Mrytle Beach SC
I would like to see pictures too
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2340175
07/20/17 08:54 AM
07/20/17 08:54 AM
Lees Summit, MO
BrianT Offline
BrianT  Offline
Lees Summit, MO
Another great and useful thread ruined thanks to Photobucket's greed.
1970 Duster 340 clone
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2340190
07/20/17 09:41 AM
07/20/17 09:41 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I'm glad I never used photobucket.
it does sux for those who do searches for some great tech info only to be screwed by lack of photos.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2359359
08/24/17 10:15 PM
08/24/17 10:15 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
I apologizes for the long delay,a lot of irons.
Here are some pictures of my tierods.
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2368250
09/10/17 12:36 PM
09/10/17 12:36 PM
Mrytle Beach SC
Mrytle Beach SC
I did like moparborn, I made some tie rod sleeves out of stainless,
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2368253
09/10/17 12:42 PM
09/10/17 12:42 PM
Mrytle Beach SC
Mrytle Beach SC
I made some press in taper sleeves to use the speedway pinto heim studs. Im mounting the Heims on the bottom. If I get some bump steer I will mount them on the top. I need to tighten things up, Do the bump stops and get a Alignment. The crossmember might be to close to the ground, I may have to raise it a hair. But no more Camber or tie rod angle problems.
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2368580
09/11/17 12:04 AM
09/11/17 12:04 AM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Nice job.they look good.
Re: How to Lower Your 1972-1993 Dodge Pickup [Re: Kevin I] #2427114
01/01/18 02:58 PM
01/01/18 02:58 PM
Texas,usa
W
Wesd100 Offline
Wesd100  Offline
W
Texas,usa
Great write-up, bloody photobucket fn it up.
