Re: 11.75 pin type brake caliper bracket
[Re: DaveRS23]
#2230911
01/09/17 05:19 PM
01/09/17 05:19 PM
Posts: 1,440 NW Chicago suburban area
Mopar Mitch
Question about disc pads (inside and outside) -- aren't the pin-type pads slightly larger in square surface area vs the slider type pads? IF yes, then there is an advantage, IMO, to having the pin-type calipers (or whichever is larger, speaking for both the inside pad and the outside pad).
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Devil]
#2231017
01/09/17 07:25 PM
01/09/17 07:25 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Dunno, I do know that the pin type has more options in regards to friction material choices though thru Hawk. But Firm Feel does have some for the slider types too.
[Re: Supercuda]
#2231412
01/10/17 03:47 AM
01/10/17 03:47 AM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
In 1973, the pin caliper's fluid port location changed.
Hose routing is funky when this caliper is mounted toward the front on muscle era Mopar A,B, and E bodies. When this caliper is mounted toward the rear, the brake hose banjo bolt hits the lower control arm before full lock!
'70-'72 pin calipers are fairly scarce and costly. These fit nicely when mounted toward the front, but hose routing suffers when installed toward the rear.
Due to clearance purposes, most pre '73 A-bodies equipped with sway bars and pre '70 B-bodies equipped with sway bars require rear mounted calipers.
[Re: DoctorDiff]
#2231753
01/10/17 05:52 PM
01/10/17 05:52 PM
Posts: 10,498 Chicago, Illinois
Devil
Chicago, Illinois
Due to clearance purposes, most pre '73 A-bodies equipped with sway bars and pre '70 B-bodies equipped with sway bars require rear mounted calipers. Wow, thank you for that. I my calipers have been sitting for a decade. I hope they are still good. I can rebuild them I believe though. Dr. Diff, if I wanted to upgrade to the 11.75 rotor on my 71 Challenger. It would appear I need your sleeve kit to make it work? http://www.doctordiff.com/70-72-b-e-body-disc-brake-spindle-sleeves.html
[Re: DoctorDiff]
#2232395
01/11/17 06:21 PM
01/11/17 06:21 PM
Mopar Mitch
Question -- Can the 72-older (72-71-70) pin type calipers be used on the 11.75 rotors... and must they, then simply, require the B-body caliper brackets for the 11.75 rotors? Also, will those 11.75 pin-type caliper brackets properly attach to the 72-older e-body disc brake spindles?
I believe the answers to above ar YEs, but, i just want to be re-confirmed.... then I'd need the DrDiff sleeve kit instead of swapping the spindles.
Mopar Mitch
[Re: DoctorDiff]
#2232933
01/12/17 04:39 PM
01/12/17 04:39 PM
Mopar Mitch
DR Diff/Cass -- T/Anks for the confirmation... saves some $$ to spend on other items.. such as your rear disc 10.75 setup! I'll contact you soon!
Now, I just need to locate the B-body 11.75 pin-type brakets (front end of car is apart now... timely to find them!!!).
Mopar Mitch
