Cam Range vs Conv Stall #222673
02/12/09 10:47 PM
02/12/09 10:47 PM
Raleigh N.C
hemiparts Offline OP
"Missile Pilot"
"Missile Pilot"
Raleigh N.C
Where in the cam range is should your converter stall be ?? We just put a new cam in the Duster range is 4k-8k and we're using a 4500 stall conv and was just wondering
Re: Cam Range vs Conv Stall [Re: hemiparts] #222674
02/12/09 11:54 PM
02/12/09 11:54 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
For best ET the stall RPM on the converter should be a little above peak TQ of the motor. Can't tell where that would be from the RPM range of the cam. Need need more info on the motor then what the cam company show's as the RPM range.
Re: Cam Range vs Conv Stall [Re: hemiparts] #222675
02/13/09 12:01 AM
02/13/09 12:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
As a general statement, your torque will be 1500
rpm below the max hp so in your case.... if peak
HP is at 7800-8000 you want the TC to stall near
6300-6500. Of course this is IF all the other parts
fall in line for a peak HP in the 7800 range. If not
then all of it is a guess
Re: Cam Range vs Conv Stall [Re: hemiparts] #222676
02/13/09 12:57 AM
02/13/09 12:57 AM
Go try it first, before fixing it
