Rear disc brake? #222658
02/12/09 10:38 PM
02/12/09 10:38 PM
Eastern Shore of Maryland
N
nasty68 Offline OP
nasty68  Offline OP
N
When i ordered my rear axle's from moser i had told the guy i would be running either wilwood or aerospace disc's. My questions is it looks to me that the caliper bracket slides around the axle and bolts to the housing. My axles have the sealed bearings and have a retainer on them. Does the caliper bracket bolt over top of the retainer or does the retainer have to be removed from my axles and then the caliper bracket bolt on? Sorry if this sounds confusing.
68 dart, 383, 727
2013 Jeep JKU Sahara
Re: Rear disc brake? [Re: nasty68] #222659
02/12/09 11:47 PM
02/12/09 11:47 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
I have the Aerospace brakes. The kit has it's own retainer/bracket
and the original retainer is not used.
Re: Rear disc brake? [Re: S/ST 3040] #222660
02/12/09 11:50 PM
02/12/09 11:50 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have aerospace also and you need the green bearing were the retainer is separate. and you will use the one that aerospace gives you, which is in the shape of a C
Re: Rear disc brake? [Re: 70blackfish] #222661
02/13/09 12:21 AM
02/13/09 12:21 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I have wilwood brakes and had to remove the retainer from the bearings. The caliper brackets act as the retainer.
Re: Rear disc brake? [Re: WILD BILL] #222662
02/13/09 07:24 AM
02/13/09 07:24 AM
N
nasty68 Offline OP
nasty68  Offline OP
N
Thanks guys, i was thinking that it was going to have to come off but i figured i would ask some people that would know.
68 dart, 383, 727
Re: Rear disc brake? [Re: nasty68] #222663
02/13/09 07:35 AM
02/13/09 07:35 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I just got my mosers axle last week with 5/8 studs.i have wilwood rear brakes but like Bill said u won't need the moser retainer you will use the black retainer that hold the caliber to the housing.also if anyone going to use 5/8 studs will need the drill the 1/2 hole with a 11/16 drill bit which I felt spending that kind of money that should be an option when one order the brakes
Re: Rear disc brake? [Re: Otherlane] #222664
02/13/09 07:43 AM
02/13/09 07:43 AM
Q
Quicktree Offline
Quicktree  Offline
Q
with it should be an option, I doubt you get 11/16 to work. it was still tight on my 5/8 studs. it had to go to 3/4 to clear.
Re: Rear disc brake? [Re: Quicktree] #222665
02/13/09 08:47 AM
02/13/09 08:47 AM
Delmont, Pa.
SRT8Challenger Offline
Delmont, Pa.
I have Moser axles and the green bearingsd also.
Just received my rear Aeorspace race brakes.
I talked to aerospace and was told if the studs are long enough to go ahead and use both retainers, Aerospace aluminum first the the Moser one. If the studs are not long enough then i will need to cut the Moser retainer off.
I measured the stud length and it looks to be long enough, in either case the Aerospace braket becomes the bearing retainer.
Ed
Re: Rear disc brake? [Re: Otherlane] #222666
02/13/09 09:41 AM
02/13/09 09:41 AM
S/ST 3040 Offline
S/ST 3040  Offline
AEROSPACE BRAKES
Re: Rear disc brake? [Re: S/ST 3040] #222667
02/13/09 10:26 AM
02/13/09 10:26 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Thanks quicktree,glad u said that before I use this drill bit.When I called moser he said 11/16 bit but you have tried it but didn't work so back to the store
Re: Rear disc brake? [Re: S/ST 3040] #222668
02/13/09 12:08 PM
02/13/09 12:08 PM
Riverside, California
Lil Demon Offline
Lil Demon  Offline
AEROSPACE BRAKES
5/8" studs are an option with Aerospace.
Re: Rear disc brake? [Re: Otherlane] #222669
02/13/09 12:28 PM
02/13/09 12:28 PM
Q
Quicktree Offline
Quicktree  Offline
Q
check it before you drill !!!!! your studs may be different than mine. you will have to di it on a drill press.
Re: Rear disc brake? [Re: nasty68] #222670
02/13/09 12:46 PM
02/13/09 12:46 PM
Winnipeg, Canada
StrokerDart Offline
StrokerDart  Offline
Winnipeg, Canada
I have the Aerospace brakes (thanks Lil Demon) and I was planning on just sandwiching the caliper bracket between the housing and the retainer already on my Moser axle/sealed bearing combo... rather than cutting it off
Re: Rear disc brake? [Re: StrokerDart] #222671
02/13/09 01:36 PM
02/13/09 01:36 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
Well when I brought my k-member it came with the wilwoods so that why I am using that brand. But quicktree I have both drill bit now but I will see which one will work the best before drilling.Like to return one back so I can get my $20 back?lol
Re: Rear disc brake? [Re: Otherlane] #222672
02/13/09 09:08 PM
02/13/09 09:08 PM
N
nasty68 Offline OP
nasty68  Offline OP
N
Thanks for the link to that thread. Customer service goes a long way and it makes me lean heavily towards aerospace.
68 dart, 383, 727
