E body dash dimmer switch cleaning #2225896
01/02/17 09:56 PM
01/02/17 09:56 PM
PNW
Danan Offline OP
Danan  Offline OP
PNW
My dimmer switch isn't functioning. When I took it apart I noted that whatever had been used to retain the stainless rheostat spring inside the ceramic holder had failed. It had turned to white powder. I have everything cleaned up and ready for reassembly but curious to hear what ya'll use retain the spring. Epoxy? Silicone?
Thanks!
Re: E body dash dimmer switch cleaning [Re: Danan] #2225909
01/02/17 10:14 PM
01/02/17 10:14 PM
what about some JB weld?
Re: E body dash dimmer switch cleaning [Re: Danan] #2225933
01/02/17 10:43 PM
01/02/17 10:43 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
I bypass it on my Challenger. Last thing it needs is a dimmed down dash instrument panel. A "U" shaped short jumper wire with a couple of electrical male tabs affixed is what I used. A toggle switch under the dash controls the dome light.
Re: E body dash dimmer switch cleaning [Re: Danan] #2225966
01/02/17 11:25 PM
01/02/17 11:25 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
Thanks!
the man to ask is Jim at JS restorations
jsrestorations@rocketmail.com or JS Restorations on this board
Re: E body dash dimmer switch cleaning [Re: mikemee1331] #2226100
01/03/17 01:57 AM
01/03/17 01:57 AM
PNW
Danan Offline OP
Danan  Offline OP
PNW
Thanks; I couldn't in good conscience ask a guy who restores switches for a living to tell me his secrets. I figured that many people had been down this road before me, and could tell me what's worked for them.
JB weld might be a good option, thanks for the suggestion.
Re: E body dash dimmer switch cleaning [Re: Danan] #2226185
01/03/17 10:10 AM
01/03/17 10:10 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
of course but Jim is more about the hobby.......
Re: E body dash dimmer switch cleaning [Re: Danan] #2226685
01/03/17 10:54 PM
01/03/17 10:54 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
That coil acts as a resistor, meaning it will get hot, hence why over the years the original bedding compound they used broke down over time and why the surrounding material resembles a type of ceramic. I'd bet it's closer to plaster of paris than any type of glue - some sort of hardening cement type of material, same as used in ballast resistors. Not sure I'd try JB Weld on it. It's good stuff but like any other epoxy I believe heat will soften it.
Re: E body dash dimmer switch cleaning [Re: Sixpak] #2226919
01/04/17 04:14 AM
01/04/17 04:14 AM
PNW
Danan Offline OP
Danan  Offline OP
PNW
The powder did resemble Plaster of Paris. I'll give it a shot. Thanks!
