Re: Had a pretty good streak of luck until lastnight [Re: dc426] #222283
02/13/09 11:23 AM
02/13/09 11:23 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I'm gonna end up pulling anyway to rule out everything. Plus I've been meaning to get it out to freshen it. I've been collecting goodies for it including a brake, so I guess no better time than now.
DC
I hope one of those goodies is a billet drum
Re: Had a pretty good streak of luck until lastnight [Re: WILD BILL] #222284
02/13/09 12:09 PM
02/13/09 12:09 PM
Tampa Florida
dc426 Offline OP
gotta keep'm separated
dc426  Offline OP
Tampa Florida
steel billet from CRT
Re: Had a pretty good streak of luck until lastnight [Re: dc426] #222285
02/13/09 12:24 PM
02/13/09 12:24 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: Hey !! Bills on a good streak !! [Re: dc426] #222286
02/13/09 01:10 PM
02/13/09 01:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I know on mine I could only notice one shift when I was spinning the wheels off the ground. But it shifted fine when I drove it and had all gears.
I'm basing this on the fact that it revved like it was in neutral in second gear while trying to do the burnout. I may drop the pan today before I go to work.
DC
That's weird because the rear clutch is applied in ALL forward gears, so it should still move in 2nd and/or 3rd , just never shift 2nd only applies the front band.
I can't remember what the overrunning clutch is doing in 2nd and 3rd , but it sounds like something is broken .
Re: Hey !! Bills on a good streak !! [Re: JohnRR] #222287
02/13/09 01:42 PM
02/13/09 01:42 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I don't have my book in front of my but IIRC the over running clutch is not used in 2nd or 3rd.
Re: Hey !! Bills on a good streak !! [Re: WILD BILL] #222288
02/13/09 02:02 PM
02/13/09 02:02 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm no tranny guy, but the book says
When the shifter is in reverse:
front clutch is ON
rear clutch is OFF
kick down band is OFF
low reverse band is ON
over running clutch is OFF
Shifter in manual low
front clutch is OFF
rear clutch is ON
Re: Hey !! Bills on a good streak !! [Re: MR_P_BODY] #222289
02/13/09 02:08 PM
02/13/09 02:08 PM
Tampa, FL
tpabayflyer Offline
tpabayflyer  Offline
Tampa, FL
Bummer.... I'm sure Rebel can hook you up with a fresh buildup... That baby is going to launch like a cannon when you hit with the brake...... TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: Hey !! Bills on a good streak !! [Re: WILD BILL] #222290
02/13/09 02:27 PM
02/13/09 02:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bill, you are correct, the over running clutch is
over running in both 2nd and high gear... this is a
manual valve body.
Reading some of the trouble shooting checks it does
sound like he broke (or blew out) the kick down band
servo. I am thinking it isnt up shifting
Re: Hey !! Bills on a good streak !! [Re: MR_P_BODY] #222291
02/13/09 06:29 PM
02/13/09 06:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Raff , it would always stay in first unless there is a huge pressure loss on the 2nd gear shift that is releasing the rear clutch ????
dc is it not shifting and loosing forward motion once it goes for second or just a no shift issue ?
