Re: Need dependable roller lifters
[Re: sc301v]
#222119
02/12/09 01:22 PM
02/12/09 01:22 PM
Posts: 30,989 Oregon
AndyF
Call the guys at Best Machine. They have a private brand roller lifter that will do exactly what you need.
I'm not sure why they don't advertise these lifters but they have them.
[Re: sc301v]
#222120
02/12/09 01:32 PM
02/12/09 01:32 PM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
Look into Isky red zone lifters. I got them from Scott Brown. They are offset on the intake with pushrod oiling and my block (KB) is not bushed. I run some healthy spring pressures but I don't recall the exact numbers.
[Re: boatracer572]
#222126
02/12/09 06:04 PM
02/12/09 06:04 PM
Posts: 364 Kentucky
sc301v
Kentucky
Comp 892 lifters for pushrod oiling I run valve spring pressures at: 450lbs closed,1280lbs open! ive been running them for years at 8400 rpms.and rotate them out at 150 passes,Never broke one!!!
Are those a full bodied lifter or do they have the cutout.
I found some 829s but couldnt find the 892s
[Re: sc301v]
#222127
02/12/09 06:44 PM
02/12/09 06:44 PM
AndyF
Anybody got any part #s for any of these lifters. The websites arent showing much on the mopars.Not that i can see anyway. Thanks again
Call Best Machine.
[Re: sc301v]
#222129
02/12/09 06:52 PM
02/12/09 06:52 PM
Posts: 136 CHANDLER, AZ
512 VALIANT
CHANDLER, AZ
ISKY RED ZONE PART# 3472RH
[Re: Cab_Burge]
#222130
02/12/09 07:42 PM
02/12/09 07:42 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Crane Ultra or Jesels
I agree. Anything else is a crap shoot for serious applications.
[Re: Diablo]
#222134
02/13/09 09:41 AM
02/13/09 09:41 AM
Posts: 364 Kentucky
sc301v
Kentucky
I've just bought a set of Crane .210 offset, pushrod oiling. im lifting close to an inch in my 600++ci engine
Dont guess you have a part# would you.
And also do you run them in an unbushed block.
[Re: Brian Hafliger]
#222136
02/13/09 10:51 AM
02/13/09 10:51 AM
BobR
Left Coast
I sell these: Pushrod oil, edm oil to the bearings, moved oil hole, shrouded wheel, available with no offset or .180 offsets. Brian
Probably need to have the bores bushed to get any kind of decent oil pressure.
[Re: BobR]
#222137
02/13/09 11:26 AM
02/13/09 11:26 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Where do you guys come up with this stuff??????????????????????????????????????????????????????????????????????????????? These lifters go right in, no problem, no bushing. Infact these lifters are made so you can run quite a bit of lift WITHOUT bushing the block!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Ask some board members who have bought from me, like Cudabin and AndyF!!!! Brian
