Distributor pickup phasing
#2219140
12/22/16 05:42 PM
12/22/16 05:42 PM
Posts: 4,220 West Plains, MO
DrCharles
West Plains, MO
Today I put medium springs in my distributor and set the FBO plate to 10 deg advance. Fired it up and set the initial to 24 degrees. Still has a Top Fueler idle but with 272@.050 I can't say that's a surprise. Idle vac only about 5" and quite unsteady. I hooked up the can to a Mity-Vac and gave it a squeeze... the timing mark suddenly changed a huge amount and the engine died. Let off the vacuum and it caught again. What I think that's telling me is there's a phasing problem, but not with the rotor to cap (the vac advance moves the pickup plate, not the rotor). Only the centrifugal advance moves the rotor relative to the cap Just to add to the fun, as the engine was coming to a stop the second time, I let the distributor pickup wires get caught in the alternator belt/pulley and it ripped them up. But it's not all bad - looking at the mess, I realized that I'd connected the wires backward from the reluctor pickup... which is probably also causing my phasing problem! Fuel pressure also 4.5 lbs, idle mixtures 1.5 turns out, secondaries cracked... lots of things still to tune. Oh well, enough for one day!
Re: Distributor pickup phasing
[Re: DrCharles]
#2219596
12/23/16 01:52 PM
12/23/16 01:52 PM
RapidRobert
What I think that's telling me is there's a phasing problem, but not with the rotor to cap (the vac advance moves the pickup plate, not the rotor). Only the centrifugal advance moves the rotor relative to the cap. Yes the can moves the plate which does alter rotor to cap alignment when it fires (RP) and centrifugal advance does not. when you pump up the can it changes RP and also greatly increases the reluctor gap & if you are at .008" at rest then that is OK & either one out of whack or a combo of both can cause it to act up. fix the wiring/set the reluctor gap at .008" with a brass gauge or just get it close but not touching & it might be slightly closer at the bottom so eyeball it good. On RP You are at an advantage cuz have the pump at your disposal. turn housing till the magnet is dead even with a tooth & lock it down & make a mark on the metal dist housing outer top perimeter rim just below where the cap seats for where it is clocked (confirm that the springs are retracted all the way which they should be but the slots could be gummed up so twist the rotor back against rotation to confirm) then replace the cap & make another mark on the rim vertically inline with the cap terminal bulge next to the 1st one then remove the cap for easier viewing & see how far they are off then pump it up & see how far it shift away from an acceptable alignment. RP from the can shifts CW on a BB and CCW on a SB & it shifts .024" around the arc for every degree of vac adv (see the # on the bottom of the can arm). the cap terminal width is .214" and the rotor terminal width is .244" & you want them in close proximity & also there is the radial distance from rotor tip to cap terminal and when the combo of RP and radial distance becomes greater than what the available voltage can jump then it will misfire (+ the reluctor gap issue potential). if you need to change RP position or increase rotor tip dimention holler & I will give more info & 3 or 4 options for that.
[Re: 383man]
#2221060
12/26/16 01:44 PM
12/26/16 01:44 PM
RapidRobert
the pickup generates its AC voltage when the tooth JUST moves past being dead on with the magnet so a .069" change in distance before reaching that "position" (from switching polarity directions) would change crank timing 12 degrees (& change phasing)
Re: Idle timing
[Re: DrCharles]
#2221081
12/26/16 02:21 PM
12/26/16 02:21 PM
DrCharles
West Plains, MO
Wires swapped, timing reset. New problem... with my big cam (272@.050) it won't idle properly with up to 24 degrees initial, unless the PCV hose is disconnected allowing more fresh air into the engine. Carb is set to .020 (square) transition slots on pri & sec, and 3/32 holes in the primary throttle blades). In fact it likes full advance (34-36) at idle. But that will certainly cause a hot starting problem... I do have a dash-mounted retard unit that has 0-15 degree range. So I see three work-arounds: 1) Always remember to turn the dial to -15 degrees when hot starting; 2) Use super-light distributor springs so advance all-in by 1200 (idle); 3) Start cranking then turn on ignition. I'm thinking about the super-light springs. I already have an FBO limiter plate. That way the cranking timing will be 18 degrees, but when it starts the timing will immediately come up to 34. Thoughts?
Re: Idle timing
[Re: DrCharles]
#2221189
12/26/16 04:52 PM
12/26/16 04:52 PM
DrCharles
West Plains, MO
That's what I figured, so as I posted, I already drilled 3/32" (~.100) holes in both plates. Not nearly enough. If it idles "right" with a foot of PVC hose hanging off the 3/8" baseplate port, that's going to require huge holes in the blades to let in that much air.
Re: Idle timing
[Re: DrCharles]
#2221194
12/26/16 04:59 PM
12/26/16 04:59 PM
RapidRobert
I wouldn't want locked out advance for the street. I'm wondering if we are missing something related to the AF ratio (which is what we are trying to figure out) OR if it needs a more race orientated carb to go along with that cam
Re: Idle timing
[Re: DrCharles]
#2221198
12/26/16 05:02 PM
12/26/16 05:02 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What is the PCV hose plugged into when it is not "idling right"?
Re: Idle timing
[Re: DrCharles]
#2221249
12/26/16 06:57 PM
12/26/16 06:57 PM
Supercuda
About to go away
About to go away
up yours
Odd, I was thinking the PCV might be too small not allowing enough air flow, but then you did the hose trick in the cover and that ruled that out. Unless you are somehow kinking the hose or blocking flow someway? Maybe the hose if bad internally?
Re: Idle timing
[Re: DrCharles]
#2221269
12/26/16 07:41 PM
12/26/16 07:41 PM
DrCharles
West Plains, MO
I changed the oil, now Brad Penn 10W-40 "With High Levels of Zinc and Phosphorus!" Says so right on the bottle The break-in oil did smell a bit gassy but no obvious metal particles. Only a very small amount stuck to the magnetic oil pan plug. Don't have a filter cutting tool at the moment but I saved the filter. With the timing set at 34 initial, the idle is acceptable at 1000-1100 rpm and 6-7" vacuum and the PCV connected. Wideband showing mostly 13.5:1 although it does wander some between 13 and 14. It does fight the starter a bit after several minutes shut down, but dialing out some timing from the dash took care of that. Guess I will have to lock out the distributor... Disconnecting the PCV hose at the valve now causes too fast an idle (1600 and 9" vac). I can control the idle speed with my thumb partially plugging the hose. Hard to drive that way though. Perhaps R. Dogdays had the right idea - drill the throttle blade holes somewhat larger, maybe to 1/8"... At some point (soon) I'm going to quit tearing my hair out and send it to Thumperdart!
Re: Idle timing
[Re: DrCharles]
#2221293
12/26/16 08:22 PM
12/26/16 08:22 PM
Supercuda
About to go away
About to go away
up yours
Don't tell me you have vacuum advance hooked to manifold vacuum.
Re: Idle timing
[Re: BradH]
#2221385
12/26/16 11:15 PM
12/26/16 11:15 PM
DrCharles
West Plains, MO
Don't tell me you have vacuum advance hooked to manifold vacuum. Doesn't matter where I hook it, there's not enough vacuum at idle to activate the can! Right now I don't have it hooked to anything. Questions: 1. Have you drilled all 4 throttle blades, or only the primaries?
2. Why are you trying to run a PCV valve on an engine like this? You really don't want that recurculated sh!t getting sucked back into your induction system...
3. Where is your vacuum advance connected (direct manifold vacuum or a carb port that only pulls vacuum at higher RPM, but not at idle)?
4. Stick car or automatic, and what stall if an auto? OK, in the order you asked: 1) only the primaries with 3/32" holes so far. 2) to get the "recurculated sh!t" ventilated out of the crankcase, I don't like sludge and acid formation... although I have considered just installing a second breather. 3) see above. Doesn't matter at 6-7" of idle vacuum. 4) stick. What do you think?
Re: Idle timing
[Re: DrCharles]
#2221418
12/27/16 12:09 AM
12/27/16 12:09 AM
DrCharles
West Plains, MO
Thanks for the data! Those are quite similar parameters to my initial try (1200, 24/34 in by 3000), except that I didn't have .110 holes in all four plates. With 3.91 gears and 295/50R15 tires, I will also be cruising at 3000+. I have noticed that this cam idles smoothest at 1200 also, although it will tolerate 1000 but a fair bit lumpier. Would you recommend the four smaller holes over two larger ones? I'm thinking that if I screw up, I only have to repair or replace two blades
Re: Idle timing
[Re: DrCharles]
#2221424
12/27/16 12:20 AM
12/27/16 12:20 AM
BradH
Start with 4 x . 093 or .100 and see if that gives you enough bypass air. Throttle blades are cheap and you can buy pre-drilled sets, too.
Oh, dump the PCV and run at least 2 breathers.
Re: Idle timing
[Re: DrCharles]
#2221574
12/27/16 01:00 PM
12/27/16 01:00 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'd be curious as to what the cranking compression is.
I can tell I've gotten older....... The 272deg cam and "street" duty no longer seem like a good idea to me, whereas 25 years ago I would have been up for trying it(maybe).
